Go to Post its pretty great when non FIRST friends go into your purse for chapstick or something and find a spike... - anna~marie [more]
Unread 30-01-2009, 00:17
pyr0b0y pyr0b0y is offline
Programmer/Electrical
AKA: Josh
FRC #0253 (Mills Robotics Team)
pyr0b0y is an unknown quantity at this point
Send a message via AIM to pyr0b0y
Removing Code
ok so i download some code to the crio and it worked fine with the joysticks. i am now trying to take the code off of the crio completely...what is the best way to erase it from the crio???
Unread 30-01-2009, 11:54
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
Re: Removing Code
You shouldn't need to manually remove code from the cRIO. Whenever you deploy something new to it the old code will automatically be removed and replaced with the new code.
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 30-01-2009, 13:23
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
Re: Removing Code
Also, if you just click run in Labview it sends the program to RAM. Therefor when to cRIO restart it won't be there anymore. This is assuming that you didn't deploy it to flash which is a different process.
Unread 01-02-2009, 23:24
AKA: Josh
Re: Removing Code
well i was just trying to run 1 motor at first. so i deployed it and it worked fine, but i updated the code, and have been trying for 5 days and have not been successful in getting a motor to run again. btw this is only for teleoperated, i uploaded auto code and itll just go in to auto mode, even if i manually switch it to tele from the driver station....whats going on?
i have tried also uploading the whole project, but that doesnt do anything either
Unread 02-02-2009, 09:00
Re: Removing Code
If you have a motor that isn't moving, and it is a SW issue, you are probably getting an error. You should always probe or look at panels or run the dashboard to see what they are and let them help with the debugging.
Greg McKaksle
Unread 02-02-2009, 09:56
Re: Removing Code
I've found this not to be true after Update 3.0a.
If I don't remove the default code (added to the cRIO by Imaging with the latest update) then it will be running at the same time as my newly downloaded LabVIEW code.
You can easily test for this by booting the cRIO while the DS is set to autonomous mode. You'll see the chase lights on the solenoid module until the larger LabVIEW program has time to finish loading and take over.
Removing game pieces from Trailers PhilBot Rules/Strategy 51 06-01-2009 17:19
removing trackball from overpass Tyler Grooms Rules/Strategy 4 15-01-2008 12:39
Removing Bumpers for Ramp Gabe Technical Discussion 8 21-02-2007 10:28
RE:Removing Tetras matt111 Rules/Strategy 40 12-01-2005 12:48
Removing Drill pinion Rickertsen2 Technical Discussion 14 18-02-2004 13:41
