Go to Post sometimes you have to put up with the rain to see the rainbow - Beth Sweet [more]
Unread 30-01-2009, 14:11
Re: Common Ground for DSC
Eric,
Any one signal can affect the other signals that are combined. It is unlikely that the noise component would cause problems in your configuration but anything is possible. I still point to the single failure. A defective ground takes out as many as four of your sensors, while individual wires may only take out one. I would like to understand the term "buss" in your configuration. Are you referring to common power supply connections or summing several sensor inputs to one connection?
Servos, DSC and labview Team2883 General Forum 2 16-01-2009 14:47
Common Ground? morpheous115 Electrical 8 11-02-2008 11:43
Common ground for sensors? Jared Russell Electrical 1 03-02-2006 07:25
Common Ground on Limit Switches Gary Bonner Electrical 4 18-02-2005 13:24
Common For MAXI MikeDubreuil Electrical 1 10-02-2003 02:35
