Go to Post Read it, Loved it, posted it on facebook! - wendymom [more]
Unread 30-01-2009, 14:00
Shira Shira is offline
FRC #1836
Shira is an unknown quantity at this point
pic: Chassis Base
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: pic: Chassis Base
No joke -- this look almost identical to our 2008 frame! I bet it even weight 5.75 lbs too.
GitHub
Unread 30-01-2009, 14:20
Does it use anti-gravity, or is that girl fastened to some hidden supporting structure?
Unread 30-01-2009, 14:30
ScottieDo555's Avatar
ScottieDo555 ScottieDo555 is offline
Best of the best
AKA: Scott Donaldson
FRC #2219 (MegaHurts)
ScottieDo555 can only hope to improve
Send a message via AIM to ScottieDo555 Send a message via MSN to ScottieDo555
did you guys grind the welds. if so its not the best idea. or so ive herd.
Team MegaHurts 2219
BEST PAINTBALL FORUM - www.mcarterbrown.com - BEST PAINTBALL FORUM
Unread 30-01-2009, 15:51
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
Talking Re: pic: Chassis Base
cool frame, cute girl, they go great together lol
Unread 30-01-2009, 16:12
Anna B.'s Avatar
Anna B. Anna B. is offline
has lots of NASA swag!
AKA: Anna
FRC #1735 (Green Reapers)
Anna B. is a glorious beacon of lightAnna B. is a glorious beacon of lightAnna B. is a glorious beacon of lightAnna B. is a glorious beacon of lightAnna B. is a glorious beacon of lightAnna B. is a glorious beacon of light
Love that shirt! And the frame!
raising my parents blood pressure since '94
the best numbers are made up numbers
"let's call the four things A, G, Semicolon, and Pointy"
Maxima debetur puer reverentia
The greatest respect is due a child (Juvenal)
Unread 30-01-2009, 16:17
JesseK's Avatar
FRC #1885 (ILITE)
Most of the strength of the weld comes from the inner corners where the frame members meet. Corners, such as the ones seen on the open front of this frame, are fairly weak as it is since they're on the edge; but they will hold throughout an entire 3-competition season (as was seen with us the last 2 years). Cross members, such as the middle cross member seen in the picture, are plenty strong with those two welds.
Hence, grinding the 'top' and 'bottom' surfaces does not significantly weaken either type of join so long as the welds on the inside corners are done properly. Grinding is also necessary if you plan to properly powder coat the frame...the bumps severely detract from the final look of the robot.
GitHub
Unread 01-02-2009, 14:08
FRC #1836
Actually, 14 lbs. But that's pretty light--this thing is basically max dimensions.
Unread 01-02-2009, 14:10
FRC #1836
Thank you, that's me holding up the frame.
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Velcro on the shoes....
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
c-base chassis issue? wolfeman Kit & Additional Hardware 11 04-01-2009 21:46
pic: 6w/d Chain base kajeevan Extra Discussion 9 19-08-2008 22:54
Circle base vs. Rectangle base Pelicano234 Technical Discussion 13 15-01-2008 16:49
pic: 1024 Base Michael Long Robot Showcase 4 17-02-2006 08:53
