Go to Post Like a wizard, Car Nack is never late. He always arrives precisely when he meets you. - EricH [more]
Unread 29-01-2009, 23:55
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
pic: View of 842's Shoot
Unread 29-01-2009, 23:58
Cjmovie's Avatar
Cjmovie Cjmovie is offline
1293 Resident Hacker
AKA: Christopher Corsi
FRC #1293 (D5 Robotics)
Cjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to all
Re: pic: View of 842's Shoot
Very nice! What's driving it? I can't see a motor in this picture. It's hard to tell exactly from the viewpoint here, is it narrow or wide configuration?
How tall is the conveyor, and how many balls can be held on its interior? If I were to estimate based on the picture, I'd say around 8 or 9.
*edit*
It appears this picture and the next are both from your robot, and based on that I'd have to say fisher price driving the lift in the front, a window motor driving the back, widebot configuration. Sound about right?
D5 Robotics, Team 1293: Programmer, CAD'er, Mechanical, Electrical... I've made my rounds.
Events: 2006-2009 Palmetto Regional
Website: http://d5robotics.org/
Unread 30-01-2009, 00:45
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
*edit*
Fisher price for the front (shorter belts) and a van door motor for the rear belts.
We went with narrow and ackerman steering.
The conveyor is just under the limit, and it can hold about 6 -7 balls (yet to be tested).
Everything but the wide bot config was right. (I think the pic angle may have thrown you off)
BTW we are using a prototype chassis, so the drivers can get practice while builder work out the kinks.
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 30-01-2009, 11:01
nahstobor's Avatar
nahstobor nahstobor is offline
EWCP
AKA: Shan (pronounced Shawn)
FRC #2733 (Pigmice), FRC #612 (Chantilly Robotics)
nahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond repute
are you guys still using the pneumatic piston to shoots the ball in?
Unread 30-01-2009, 13:01
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Yes we are! 3/4 bore 8 inch stroke, 25-30 psi
Faridodin "Fredi" Lajvardi KD7WKD
Unread 30-01-2009, 13:37
newyorkjr newyorkjr is offline
FRC #1477
newyorkjr is an unknown quantity at this point
Question Re: pic: View of 842's Shoot
Hey, it looks like that u have a piece of lexan resting on the ground that would allow balls to be pulled up into your bot. But isn't it illegal to have anything other than the kit wheels to touch the ground?
Unread 30-01-2009, 13:41
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
undoubtedly they will mount it higher then i ground, all you have to have is it's lower lip lower then the center of the ball, which is 4.5 inches, so they have plenty of wiggle room
Is now an engineer thanks to FIRST.
Unread 30-01-2009, 15:10
If you look at the other picture, it looks like they don't have any wheels down. So it's probably going to be a little higher.
And as for the illegality of anything other than KOP wheels, unpowered sensor wheels that don't provide resistance (either free-swiveling or omni-type) are allowed for the specific purpose of information gathering only. Anything else is illegal.
Unread 30-01-2009, 15:47
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
Thumbs up Re: pic: View of 842's Shoot
...NICE! You guys are fast, we're 3 weeks into this and you already got ur shooter done, thats incredible. Wonder how ur frames doing though
Unread 30-01-2009, 16:10
Cjmovie's Avatar
How much does the entire assembly weigh? It looks like around 40lb from here.
Unread 30-01-2009, 17:44
amariealbrecht's Avatar
amariealbrecht amariealbrecht is offline
Alicia Albrecht
FRC #2177 (The Robettes)
Team Role: Electrical
amariealbrecht has a spectacular aura aboutamariealbrecht has a spectacular aura aboutamariealbrecht has a spectacular aura about
Send a message via AIM to amariealbrecht
Thats a very cool design to get the orbit balls around the field.
I was wondering about the weight also..but also how tall is your overall "bot" for lack of a better word haha...?
Alicia Albrecht
Electrical Subteam
The Robettes 2177
Unread 31-01-2009, 00:54
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
38
Team 842 Programmer
Pictures at:
Videos -
Unread 31-01-2009, 11:55
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Looking very good. Question about the polycord material - is that the green 'rough' variety found at McMaster? What diameter did you all use and can you tell us about what worked better and what didn't in your testing? We're looking into making our polycord purchase soon and any information would be very helpful!
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
pic: 842's Robot Chassis - Carmen cheesed rear falconmaster Extra Discussion 11 07-01-2009 01:37
Team 842's ROV for NURC kE7JLM Off-Season Events 4 19-05-2008 14:03
pic: We shoot, we score!!! Wayne Doenges Robot Showcase 3 21-02-2008 17:24
Slow-Mo Videos of 842's Robot Virginia's Dream kE7JLM Robot Showcase 2 20-02-2008 12:12
pic: To shoot or not to shoot? JVGazeley Extra Discussion 2 29-03-2006 14:45
