Go to Post FIRST is like pizza. You and I may like different toppings, but in the end it's still delicious pizza. - Billfred [more]
Unread 30-01-2009, 01:29
Team2339's Avatar
Team2339 Team2339 is offline
Mentor#1
AKA: Myrle McLernon
FRC #2339 (Robolopes)
Team2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to behold
Buttons
Come on someone has to know how to make the motor run off the trigger here is the simple motor program now can someone tell me how to make it into one with a button
2008 LA Regional
2009 San Diego Regional 5th Seed, 2009 Las Vegas Regional Semi-Finalist
2010 San Diego and LA
2011 Bound for same
KQ6Y
Scientia Super Omnia
Unread 30-01-2009, 01:45
TotalChaos's Avatar
TotalChaos TotalChaos is offline
AKA: Austin
FRC #2837 (Freebird Robotics)
TotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud of
Send a message via MSN to TotalChaos
Re: Buttons
There's a couple threads you could read through that will help you get closer to your answer:
http://www.chiefdelphi.com/forums/sh...ad.php?t=72593
http://www.chiefdelphi.com/forums/sh...ad.php?t=72304
... and there's probably a few more... I'd give you some pictures and more specific advice, but I really have to go to bed. ... If you're question goes unanswered I'll get you more specifics tomorrow after school.
- Austin
The 39th Aero Squadron - Team 39! (Visit our website!)
Team Role: 3 Years as Driver - College Student/Mentor!
Freebird Robotics - On a 1 year hiatus! (Visit our website!)
Arizona 2009: Semifinalists! (69 and 498), Delphi "Driving Tomorrow's Technology" Award
Unread 30-01-2009, 11:33
solomason519 solomason519 is offline
FRC #0519
solomason519 is an unknown quantity at this point
Re: Buttons
this attached file is all you need. use the joystick get vi. use the unbundle by name vi it's under the cluster, class, and variant pallette. hook this up to the button output of the joystick. hook the output of the button to a boolean to vi its under the boolean palette and finally hook the output of the boolean to to the speed input of the set speed vi.
Unread 30-01-2009, 15:58
Team2339's Avatar
Mentor#1
AKA: Myrle McLernon
Re: Buttons
ok thanks that did exactly what i wanted now next question how do change the direction? please
2008 LA Regional
2011 Bound for same
KQ6Y
Unread 30-01-2009, 16:29
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Buttons
You're really looking for something like my post here: http://www.chiefdelphi.com/forums/sh...05&postcount=2
If you only want one direction, you only need one button and one select block. So you'd just delete the upper right hand select block and wire the lower select block to the set speed vi.
Unread 30-01-2009, 18:09
Team2339's Avatar
Mentor#1
AKA: Myrle McLernon
Re: Buttons
Thanks it works!!!!!!!!!!!
2008 LA Regional
2011 Bound for same
KQ6Y
Buttons, Buttons and more Buttons (2006) Freddy Schurr Team Organization 11 14-12-2005 21:36
UI Buttons stephenthe1 Programming 4 21-03-2005 12:58
Buttons tatsak42 Computer Graphics 4 16-01-2004 14:21
buttons rosebud Electrical 11 12-01-2003 02:02
Buttons Rob Ribaudo Chit-Chat 11 06-04-2002 17:18
