Go to Post Students dream up the ideas for bots, it is than up to the mentors and engineers to make these dreams a reality. - dddriveman [more]
Unread 30-01-2009, 16:42
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Poly Cord Roughing Up PVC
My team is using poly cord with PVC pulleys, and after running it for a short period of time, we saw that the PVC where the poly cord was running had become rough like the poly cord was eating away at it. Has anyone else had this experience? What's the solution?
Mens et Manus
Unread 30-01-2009, 16:50
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Re: Poly Cord Roughing Up PVC
how much tension are you putting on the belts? are you shortening them to 10 % like mcmaster says? what color are the belts (green, orange, clear)?
I think mcmaster is suggesting something that is overkill with that 10% try decreasing the tension on the belts....from what I understand the green cord is harder and has a rougher surface, would switching belts be an option?
good luck
Unread 30-01-2009, 18:00
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Interesting.
Did you know that you can take a piece of strong nylon string and cut pvc with it? I saw it work on an episode of 'This Old House'. It's probably the same principle here, and the cord is simply taking tiny piece by tiny piece away from the pvc as it rotates.
GitHub
Unread 30-01-2009, 18:15
yarb65 yarb65 is offline
Coach
AKA: T Bray
FRC #3189 (Circuit Breakers)
yarb65 has a spectacular aura aboutyarb65 has a spectacular aura about
we found out that more tension fixes the problem of the cord roughing up the pvc
2013 Sacramento Regional Winner (3189,701,2489))
2012 Israel Regional Winner (1662,1690,1937)
2008 Sacramento Regional Winner (1662,115,2122)
2006 Sacramento Regional Winner (1662,852,1726)
Poly Cord / rubber roller tubes? Ice Berg General Forum 6 11-01-2009 13:48
[FTC]: Lego Motor Extension Cord? ttldomination FIRST Tech Challenge 2 11-01-2009 11:52
New Team to be (Possibly) Started at Cal Poly Pomona A. Leese Starting New Teams 13 10-03-2005 01:51
Trouble finding flat pvc sch 40 PVC caps Gdeaver Kit & Additional Hardware 8 12-01-2005 14:21
710 roughing it in Atlanta Ryan Albright General Forum 5 15-04-2004 00:16
