Go to Post Sleep? What is sleep? - artdutra04 [more]
Unread 24-01-2009, 11:30
Boco Gear Boco Gear is offline
AKA: Brad Vanderhoef
FRC #0263 (Aftershock)
Team Role: Student
Boco Gear is an unknown quantity at this point
Send a message via AIM to Boco Gear Send a message via MSN to Boco Gear
Mabuchi Gearbox Assembly
My team and I made a decision that we were going to use the Mabuchi motor with the plastic gearbox on our bot but we are lost on how to assemble them to hold a shaft. Could someone help us with this?
Thank you in advance,
Brad
Unread 24-01-2009, 11:36
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Mabuchi Gearbox Assembly
Do you have Inventor?
I made a coupler to go to a 1/2 inch shaft a while ago. I could send you the part.
It was essentially a cylinder that had screws in the slots in the plastic of the output.
-Vivek
"we don't build robots, we build people"
Unread 24-01-2009, 11:40
Team Role: Student
Okay we found a coupling that will work but now the only problem is how do we mount it now to our bot we have brainstormed it and so far we have nothing.
Any Suuggestions are welcomed
Unread 30-01-2009, 16:42
Skifanatic's Avatar
Skifanatic Skifanatic is offline
AKA: Matt
FRC #0348 (NHS Robotics)
Skifanatic is an unknown quantity at this point
Send a message via AIM to Skifanatic
So how exactly do you mount a mabuchi 545 to a kit fisher price plastic gear transmission? We can't figure out how to do it because of the difference in the shaft sizes of the motors.
-2008 National FINALISTS
-2008 Curie Division CHAMPS
-2008 NYC regional FINALISTS
Unread 30-01-2009, 16:56
vivek16's Avatar
AKA: vivek
Since the bodies of the 545 and the fp are the same, you can use the same mounting pattern. For the pinion, you will have to order another 32 dp, 19 tooth gear to press onto the 545 that has a smaller bore.
-Vivek
EDIT: neither martinsprocket, mcmaster or sdp-si have 19 tooth, 32 dp gears.
Unread 30-01-2009, 17:04
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
-Vivek
EDIT: neither mcmaster or sdp-si has 19 tooth, 32 dp gears. I'll keep looking but I'm not sure what to tell you.
Maybe SDP/SI would have a 0.8 module, 20° pressure angle gear with a 3 mm bore.... (32 pitch is a close approximation, but not really the right size.) The gears you find there might be plastic, though.
The current F-Ps (as in, the ones in the kit in 2009) came with 16-tooth pinions, not 19.
Unread 30-01-2009, 17:09
vivek16's Avatar
AKA: vivek
Actually, the shaft diameters on the 545 and the fischer price should be the same....
You should just be able to remove the pinion from the fp and press it onto the 545. May I ask why you are using the 545's instead of the fischer prices? They will work better. This is under the assumption that the FPs are not already spoken for elsewhere.
thanks, Vivek
Unread 30-01-2009, 18:21
Skifanatic's Avatar
AKA: Matt
Well the shafts are different lengths so will a fisher price gear work on a mabuchi with the different shaft length?
Unread 30-01-2009, 18:45
vivek16's Avatar
AKA: vivek
I'm not sure if it will fit at all without altering the gearbox because of the length. The shaft _should_ fit the gear though, they're the same diameter.
I'll let someone with a bit more experience with pressing gears onto shafts respond.
-vivek
Unread 30-01-2009, 18:57
I haven't tried switching the F-P gear to the BaneBots RS-545 motor, but I'd advise against it. The shaft on the 545 is much shorter, and not textured like the one on the F-P. (Then again, the motors aren't that expensive, if you've got spares. You could try it and report on your success.)
Also, the Fisher-Price 00968-9015 from this year is made by Johnson, not Mabuchi. Mabuchi makes the small RS-385 motor in the kit this year.
Unread 30-01-2009, 21:51
vivek16's Avatar
AKA: vivek
The 545 shaft is significantly shorter, it also does not have the splines of the FP. I haven't tried to get a gear on there. I imagine a pressfit will be harder with the smaller, knurlless shaft. Personally, I would leave the FP's in and just use them.
Boco gear: The fischer price gearbox has bolts around the perimeter, just use longer bolts (make sure you don't risk the gearbox coming apart because of this).
Assembly of the AndyMark gearbox in Pro/E? jholland Pro ENGINEER / Creo 6 09-01-2009 17:59
254/968 Gearbox Assembly Time Study/Analysis Travis Covington Technical Discussion 8 08-05-2007 13:40
Importing assembly into an assembly... James Green Inventor 8 22-01-2004 22:17
Image Discuss: Team 25 modular gearbox and modified wheel assembly CD47-Bot Robot Showcase 6 10-02-2003 20:02
Mabuchi!!!! Ghetto_Child Motors 1 28-01-2002 20:05
