Go to Post Building a 'bot is kinda like washing your hair, but instead of "rinse, lather, repeat"... you should "engineer, test, repeat". - Andy Baker [more]
Unread 30-01-2009, 17:55
b3t4_2836's Avatar
b3t4_2836 b3t4_2836 is offline
AKA: Bill
FRC #2836 (Team Beta)
b3t4_2836 will become famous soon enough
How to Power a Rotating Turret
Our moon rocks will go straight up via conveyer and be shot using spinning wheels. Our method for aiming will be using a turntable to spin a mounted plate to deflect the moonrocks to the trailer. We have considered direct drive, gears, and belts. What method of power is a good way to spin the turret?
Unread 30-01-2009, 17:58
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: How to Power a Rotating Turret
Get a big sprocket like one of these:
http://www.ifirobotics.com/sprockets.shtml
You might have to cut out the center depending on your design but they might be what you're looking for.
-Dustin Benedict
Unread 30-01-2009, 18:07
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Sprocket on a turntable is what I've designed before and also probably the easiest. Try the 96 tooth sprocket from ifi.
"we don't build robots, we build people"
Unread 30-01-2009, 18:11
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
We attached a 25 chain on the outer rim of an aluminum plate mounted to the lazy susan.
Then, we attached a FP motor (with the accompanying plastic gearbox) with a custom hub/sprocket attachment to directly drive and spin the fixed chain.
The speed and "smoothness" of running it is to our liking. No jitters of course.
Will take some pics and post once we get our encoder on for camera control purposes.
Unread 30-01-2009, 19:59
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
One way we came up with, was to rivet some gates belting (ribbed side out) to the outside of the turntable (This basically turns it into a a giant gear).
Then loop a second belt around it and a gear that goes to the drive motor.
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
Unread 30-01-2009, 20:30
Seat Ninja's Avatar
Seat Ninja Seat Ninja is offline
Still waiting for the boltstretcher
FRC #0686 (Bovine Intervention)
Seat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of light
Send a message via AIM to Seat Ninja
I thought about that and realized that the bend in the belt would alter the spacing between the teeth on the belt, thus making the two belts not fit together. This was true with the KOP belts and pulleys, but i don't know how this effect would play out on a larger wheel.
Can you play Crysis?
Unread 30-01-2009, 21:25
commodoredl commodoredl is offline
AKA: Dan Lavoie
FRC #2877 (LigerBots)
commodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud of
We purchased a larger turntable than the KoP one from McMaster Carr. We attached bolts in a circle around the border of it. We then put a timing belt around the bolts which we're turning with a window motor.
Technical Mentor
Team 2877 - Ligerbots
2016-
Previously:
Team 578 - Red Raider Robotics
2007-2014
Unread 30-01-2009, 23:13
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Is your turret going more than 360 degrees in rotation?
We figured on my team for simplicity sake and since we will never have to shoot behind us into our own trailer, we only will be rotating our turret 270 degrees. Because of this, we're using belting, and we're just permanently attatching the belt to a part of the turret, and spinning it with a motor. Since the fastened part of the belting will never come away from the round turret, we'll be good. Just a suggestion if you dont want 360 degrees.
Unread 30-01-2009, 23:20
p00rleno p00rleno is offline
Team Advisor & Former Team Leader
AKA: Andy
FRC #2590 (Nemesis)
p00rleno is on a distinguished road
Make sure that if you're using a straight motor that you have limit switches around the back, I doubt you're going to wanna be shooting in to your basket, or spinning loops in circuitry for that matter.
Unread 31-01-2009, 00:20
AKA: Sierra 117
FRC #2395
We thought this might be a problem as well, but with the testing we did, It wasn't an issue for some reason... Maybe we just had good luck that day...
Unread 31-01-2009, 00:24
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We're using a V belt. Other ideas we consider include a toothed belt, attatched at the ends to the turret, and a chain, same thing. The plan is for less than 270 degrees rotation, so there really is no need to put a big sprocket on the turret.
Unread 31-01-2009, 03:01
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
We took one of the AndyMark globe motor hubs, attached it to a little nylon pulley we had left over from last year that was about the same diameter (1.5" maybe?) and screwed some scrap wedgetop tread to it. Then we just touch the tread to the outside of a 13" lazy Susan we got and turn it on. Works like a charm, and it's very simple. Not to mention, if something gets jammed and the turntable won't move (like that would ever happen, right?) it provides a failsafe so that the tread will just start slipping instead of snapping/cutting/otherwise breaking whatever was in the way.
Unread 31-01-2009, 04:31
Woodworker88 Woodworker88 is offline
Shop Rat
AKA: Michael Fagan
FRC #0190 (Gompei and the H.E.R.D), FRC #0114 (Eagle Strike)
Woodworker88 is a jewel in the roughWoodworker88 is a jewel in the roughWoodworker88 is a jewel in the roughWoodworker88 is a jewel in the rough
It would be good to mount an encoder on the mechanism to tell if it was slipping and give you closed-loop feedback as to the position of the turret.
As to the OP's question, I've used a couple different mechanisms, including a 60 tooth #35 pitch aluminum split sprocket (used in go-karts) and the Gates Powergrip GT-2 timing belts and pulleys (like those supplied in the kit).
2005-2008 FRC Team 114 (Los Altos, CA) Lead Machinist and Shop Manager
2009-Present FRC Team 190 (Worcester, MA) Lab Manager
Worcester Polytechnic, Mechanical Engineering 2012
2009 Boston Regional
GM Industrial Design, Regional Champs (thanks 61 and 1099)
"Do or do not. There is no try." -Yoda
Unread 01-02-2009, 10:59
b3t4_2836's Avatar
AKA: Bill
It's probably going to be less than 360 but we could use 360 to shoot into our own trailer if the strategy is necessary...
Unread 01-02-2009, 13:27
Mentor007's Avatar
Mentor007 Mentor007 is offline
AKA: Paul Fleming
FRC #2228 (Cougar Tech)
Mentor007 is an unknown quantity at this point
We took a lesson from old record player turntables (ask an older mentor ). The platter was often driven by just a rubber roller in contact with the platter inside edge. We are using a non KOP turntable that has an edge about 0.5 inches high. Turn a Keyang motor gear's upper portion (not the lower portion) to .625 OD. McMaster Carr sells drive rollers with a compatible ID for about $20. Slip the drive roller onto the Keyang, mount near turntable so frictional contact made to inside or outside. Works great. Our rotation rate about 10 seconds for 360 degrees. Denso's would probably yield about 7 seconds per 360 degrees on our design. Design will slip if rotation is limited for some reason and not break. There are ways to tell where you are rotationally without limit switches and encoders.... Design is safe even if exposed.
Stop by our pit at Hartford and the team would be happy to show it off. Good luck!
how to make a power connection rotate zachjo Electrical 1 02-08-2008 01:22
how to attach a carrier plate for a turret arm to the robot. vivek16 Technical Discussion 11 18-04-2007 11:16
how do you power on the robot control great_one411 Electrical 6 04-02-2003 00:46
Rotating Light - not rotating :-/ MrB Technical Discussion 17 08-02-2002 20:36
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
