Go to Post ...remember RAID 0 is a trap. - Sperkowsky [more]
Unread 30-01-2009, 20:50
starsROBOTICS starsROBOTICS is offline
FRC #2276 (S.T.A.R.S)
starsROBOTICS is on a distinguished road
Exclamation Relay Problems
i put an attatchment of the program i used. I tried to wire 2 buttons to 1 relay. On the digital i can see the green led turn on when 1 trigger is pressed and the red led turn on when the other button is pressed but the relay does not change its state. It will only turn red on the relay. Also my probes are not working. I probed a wire and the window pops up but when i press the second button the state of the probe does not change even though the relay turns red. Can anyone help?
Unread 30-01-2009, 23:12
Burmeister #279's Avatar
Burmeister #279 Burmeister #279 is offline
What Time Is It?
AKA: Nick Burmeister
FRC #0279 (TechFusion)
Burmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of light
Send a message via AIM to Burmeister #279
Re: Relay Problems
are you sure the whole thing is running? is the main case structure there turning to the state it needs to be in?
WHAT TIME IS IT? TWO SEVEN NINE!!! [Team B =) ] Awards: 4 Safety, 2 Ind. Design, 2 Xerox, 1 Nat. Champs
2009 Buckeye Semi-Finalists (1014 & 695) || 2008 GLR Safety Award || 2006 GLR Safety Award
2005 Buckeye Regional Champs (67 & 274) & GM Industrial Design Award & Safety Award GLR Quarter Finalist & Xerox Creativity Award & Safety Award National Xerox Creativity Award & Curie Quarter Finalist (1126 & 180)
2004 Buckeye Delphi Driving Tomorrows Technology Award & Quarter Finalist GLR Champs Nationals Curie Division Finalist
2003 GLR GM Industrial Design Award || 2001 National Newton Division Winner & National Champions
2000 MI DaimlerChrysler Team Spirit Award
Unread 30-01-2009, 23:40
p00rleno p00rleno is offline
Team Advisor & Former Team Leader
AKA: Andy
FRC #2590 (Nemesis)
p00rleno is on a distinguished road
Re: Relay Problems
As Burmeister stated, you might be probing the wrong spot. For example, if you put two probes on the same wire, one before a case structure and one in it, the one outside will always read, but the one inside will only read if that case is active. Else, it will display a greyed-out control. You should try probing the relay in different places, one preferably outside of that case structure. This should get it to read out properly.
~Andy
Relay vs. Jaquar Team2339 NI LabVIEW 1 30-01-2009 11:18
Programming a relay in C++ Kage C/C++ 2 10-01-2009 17:51
Relay Commands Matt Krass Programming 6 18-02-2006 23:03
DOES ANYONE HAVE PNUEMATIC RELAY PROBLEMS? archiver 2001 0 24-06-2002 00:30
Relay fault archiver 2000 2 23-06-2002 23:36
