Go to Post Part of FRC and design/engineering is perseverance. Keep your chin up, your thoughts positive, and have respect for your work and the work of your teammates. - Nathan_Fraser [more]
Unread 30-01-2009, 23:33
ffej ffej is offline
None #2357
ffej is an unknown quantity at this point
Adding non drive motors in Advanced Framwork
I'm a fairly experienced programmer but i'm having trouble creating areference for a non drive
motor in Adv. Frmwork. Labview, If it helps we'll be
using joysticks to turn it on and off, and forward and back.
Any help would be greatly appreciated.
Unread 30-01-2009, 23:38
Burmeister #279's Avatar
Burmeister #279 Burmeister #279 is offline
What Time Is It?
AKA: Nick Burmeister
FRC #0279 (TechFusion)
Burmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of light
Send a message via AIM to Burmeister #279
Re: Adding non drive motors in Advanced Framwork
if you only want to use said motors in teleop you can initiate/run/close them the same as the joystick thats in the advanced framework. I think you can also open it in auton mode as long as you close it there as well.
WHAT TIME IS IT? TWO SEVEN NINE!!! [Team B =) ] Awards: 4 Safety, 2 Ind. Design, 2 Xerox, 1 Nat. Champs
2009 Buckeye Semi-Finalists (1014 & 695) || 2008 GLR Safety Award || 2006 GLR Safety Award
2005 Buckeye Regional Champs (67 & 274) & GM Industrial Design Award & Safety Award GLR Quarter Finalist & Xerox Creativity Award & Safety Award National Xerox Creativity Award & Curie Quarter Finalist (1126 & 180)
2004 Buckeye Delphi Driving Tomorrows Technology Award & Quarter Finalist GLR Champs Nationals Curie Division Finalist
2003 GLR GM Industrial Design Award || 2001 National Newton Division Winner & National Champions
2000 MI DaimlerChrysler Team Spirit Award
Unread 30-01-2009, 23:45
None #2357
i tried that but it didn't work, i'm not with the program right now or i would show you how i did it
Unread 30-01-2009, 23:49
What Time Is It?
where exactly are the motors being used? autonomous, teleoperated or both?
Unread 30-01-2009, 23:51
None #2357
they will be used in both
Unread 31-01-2009, 00:02
What Time Is It?
mmm... hmm...
have you tried opening and running the motor in just the teleop or in just the autonomous iterative? both have initiation cases that should work. i don't have a robot here but i have labview so i can check code but not movement =/
take a look at the picture below. could you put the motor control in there?
Name:	motor in both.jpg
Unread 31-01-2009, 00:06
None #2357
Ok, so i should open the motors in the init. part of the loop, set speed, the middle state, then close in stop.
how do i wire them together?
Unread 31-01-2009, 00:27
What Time Is It?
picture =) it'll work the same with teleop.
the feedback node will appear automatically when you connect the wire from right to left
Unread 31-01-2009, 00:33
None #2357
Thanks!
i'll try this tomorrow and post the results
(i think i was making it to be to complicated)
Unread 31-01-2009, 05:26
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Have you looked at Tip Jar #9 and 10.
http://www.lvmastery.com/tipjar
They show adding servos and gyros to the typedef and propagating them basically to all modes of operation. The motors are probably the same difference. I need to do the same thing this weekend and am going to try to use Ben's example.
Unread 31-01-2009, 11:10
None #2357
it doesn't seem to work right, the motor pulses as it is bieing turned on and off
Unread 01-02-2009, 20:12
None #2357
For some reason in the code the victor is being opened, set a speed, and then closes in like half a second, any ideas why
Tank Drive with Advanced Framework in Labview finman NI LabVIEW 4 30-01-2009 13:35
using non-vex motors MarkH Motors 3 23-04-2006 21:04
2 drive motors VS 4 drive motors Conor Ryan Motors 9 19-01-2005 22:35
adding motors an ok, or not? JamizzleHavok13 Motors 1 10-01-2005 23:02
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
