Go to Post For those of you who don't want to read a block of text: Respect the Tools. - Andrew Schreiber [more]
Unread 31-01-2009, 00:29
amariealbrecht's Avatar
amariealbrecht amariealbrecht is offline
Alicia Albrecht
FRC #2177 (The Robettes)
Team Role: Electrical
amariealbrecht has a spectacular aura aboutamariealbrecht has a spectacular aura aboutamariealbrecht has a spectacular aura about
Send a message via AIM to amariealbrecht
Re: pic: View of our Harvester 842
I really like the design, are you worried about multiple balls clogging your design?
Very nice job, good swiss cheese holes ---> Good Call!
Best of luck this year,
Alicia Albrecht
Team Captain, 2009
THE ROBETTES
Unread 31-01-2009, 00:58
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Originally Posted by Sean Raia View Post
Looks good, have you done any tests?
http://www.youtube.com/watch?v=xPaFyd0bOBU
http://www.youtube.com/user/KE7JLM
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
When your not busy with FIRST try NURC
Unread 31-01-2009, 01:09
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
Originally Posted by Martino View Post
how did you attach the FP motor to the shaft? my team is working on attaching one for our picker-upper.
thanks
We got a PVC coupler that fit nicely on the outside diameter of the FP motor spinning shaft thing, drilled some holes and it mounted nicely. To give it a little more we filled on some JB qwik. From the PCV coupler we poped in the some ABS the fit the diameter and put a bolt through that.
Team 842 Programmer
Pictures at:
Videos -
Unread 31-01-2009, 01:13
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
Originally Posted by CraigHickman View Post
Out of curiosity, how well does the Window motor powered belt work? We'll have one assembled with that motor by the end of the weekend, I'm just curious if it's fast enough in practice (our math said it is).
Take a look -
Team 842 Programmer
Pictures at:
Videos -
Unread 31-01-2009, 01:14
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
Originally Posted by Michael Corsetto View Post
Depends on what you define to be "fast enough". The Denso motor has a free speed of 84 rpm's. If we assume the rollers will run at that speed (ignoring friction in the system), with a 2 inch diameter roller, and belt on both sides (ie sandwiching the ball), thats a travel rate of about 8.8 inches per second. For our system specifically, this simply isn't fast enough for us to be competitive, but every design is different. Looks great 842! Teams like you and 1726 should get special recognition for the openness you both have with your design process.
PS. I realize you did get the 2008 Chairmans Award, which is pretty good i guess , but maybe a ribbon or something would be nice as well...
HAHA, thank you
Team 842 Programmer
Pictures at:
Videos -
Unread 31-01-2009, 01:19
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
Originally Posted by 5n1p3r View Post
I love the swiss cheese design on the frame, thats allot of weight u took off.
O yes, our frame was 24 pounds and when we where done with it all it was 14.
From this -
To This -
Team 842 Programmer
Pictures at:
Videos -
pic: CD 7 ball harvester BlazinFire47 Extra Discussion 21 14-05-2012 09:56
pic: Ball Harvester falconmaster Extra Discussion 46 25-01-2009 15:33
pic: Women of 842! f falconmaster Extra Discussion 0 10-01-2009 23:31
pic: A closup view of our prototype worm-crab drive system. AndyB Extra Discussion 6 20-01-2008 00:02
pic: Rear view of our 07 'bot Cody Carey Robot Showcase 7 16-02-2007 12:29
