Go to Post Beware of the following: boredom intelligence = ??? <- could be anything... - JBotAlan [more]
Unread 30-01-2009, 15:41
dnrobotics11 dnrobotics11 is offline
FRC #2589
dnrobotics11 is an unknown quantity at this point
C++ Functions
Is there a function in the WindRiver language that allows me to take the value of the joystick (speed of motor) and make it into a variable so that you can compare how fast you are intending to go based on joystick location and compare it to the actual speed?
Unread 30-01-2009, 16:38
Re: C++ Functions
There's not a WPI library function for what you want, but there is a simple feature of the C language called an "assignment". It is implemented using the equals sign = character.
  variable = retrieve_value();
This takes the value returned by the retrieve_value() function and assigns it to the variable named variable. In order to make it work properly, the variable and the function must have the same type. (For joystick axis values, I think that type is float.)
If you didn't already know this, you should probably find and follow a basic C/C++ programming tutorial. Finding and following a knowledgeable mentor would be a good idea as well.
[edit] I'm focusing on LabVIEW this season, so I'm not confident in my ability to give correct examples using the C++ classes to an insufficiently experienced programmer. Would someone else please answer specific questions about reading Joystick data? [/edit]
Last edited by Alan Anderson : 30-01-2009 at 19:50. Reason: requesting C++ users to help out
Unread 30-01-2009, 19:05
FRC #2589
Re: C++ Functions
Thank you very much. So if I use the float variable of the retrieve_value() function I can get the joystick speed?
Unread 30-01-2009, 20:06
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Re: C++ Functions
No, I don't believe that there's a function called retrieve_value() function. Try looking at WPILib and seeing what functions there are for the joystick class.
Unread 31-01-2009, 01:40
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: C++ Functions
If you're using the SimpleRobot demo, then you would use the instance of the Joystick class to retrieve the value of the Joystick.
// assuming that there is an instance of the Joystick class called 'stick' in the current scope
float some_X = stick.GetX();
float some_Y = stick.GetY();
However, if you glance at how the joystick values are translated to motor speed (see RobotDrive.cpp), its probably not the stick values you want to look at, you'll want to look at the motor values -- which is harder if you use their RobotDrive class, which doesn't allow you to easily access the motor values unless you create the speed controller classes outside the RobotDrive class and pass it in through the constructor of RobotDrive. For this reason, we chose to write our own RobotDrive-like class.
Reading the WPILib source code is the best way to understand how things work underneath.
Unread 31-01-2009, 13:45
FRC #2589
Re: C++ Functions
Okay I'll try that. Thank you very much.
Accelerometer functions RJohnston Programming 3 03-05-2008 11:23
Camera functions. winners Programming 1 21-01-2006 19:42
Auton + Functions ten3brousone Programming 0 27-02-2005 20:11
Cordic functions... Zalumaskov Programming 1 13-02-2005 00:58
subs/functions maDGag Programming 2 16-02-2003 23:27
