Go to Post Failure is in my eyes, the key to success. If you can deal with failure, look it in the eye, and conquer it, the hard stuff won't really intimidate you any more...and you can only get better. - Andy Grady [more]
Go Back   Chief Delphi > Technical > CAD > Pro ENGINEER / Creo
Unread 31-01-2009, 13:25
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: CENTRE OF GRAVITY COMPUTATIONS IN PRO-E?
Originally Posted by OrthoDan View Post
Pro-Mechanica is limited to static analysis, so whatever you might learn about impact in a simulation will be an approximation. The CMU tutorial posted by PTC_FRC has a nice example of building a beam-type finite element model that would be a reasonable approach for welded aluminum frames, which many FRC teams use. You need to be sure to place nodal points (at the ends of beam elements) at locations where you either want to constrain the structure or apply a load. For impact protection, avoid long unsupported spans of thin walled aluminum tubing. Cross-bracing will help avoid impact related permanent bending of your frame.
To expand a little on Dan's comments, one of the biggest problems with using FEA software isn't the software itself, but rather the user...it's very easy to get results that look convincing, but which are actually quite false. Sanity-check your results with simplified test cases, and seek out assistance if necessary, in order to set up the simulation correctly.
Unread 31-01-2009, 13:27
CraigHickman
Posts: n/a
[tech snob] I'd be impressed if you could calculate the True center of gravity.... Center of Mass, on the other hand, is much easier! [/tech snob]
Whats your opinion, Pro-life or Pro-Choice? efoote868 Chit-Chat 5 28-09-2007 10:11
Center of Gravity MrForbes Technical Discussion 1 27-01-2007 19:03
center of gravity and energy macwhoo Rules/Strategy 2 17-01-2007 17:08
Center of Gravity Sachiel7 Inventor 8 02-03-2005 11:00
anti-gravity-gas Adams High Man General Forum 24 28-02-2004 14:43
