Go to Post Many would say it is both gracious and professional to make sure your robot will not damage another team's robot. - 4throck [more]
Unread 31-01-2009, 12:31
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
Time precision better than seconds??
For a while out team has been looking to use a timer. The timer works well, except we need to have a more precise timer than the one that the documentation says is available. Is there a way to make a timer that is more precise (milliseconds/microseconds)?
Unread 31-01-2009, 13:20
Eric Finn's Avatar
Eric Finn Eric Finn is offline
FRC #0166 (Chop Shop)
Eric Finn has a spectacular aura aboutEric Finn has a spectacular aura about
Send a message via AIM to Eric Finn
Re: Time precision better than seconds??
If I recall correctly, pretty much everything having to do with time is doubles, so that you have millisecond resolution for the time, but it is measured in seconds. That is, 200 ms would be 0.2 seconds.
It always takes longer than you expect, even when you take into account Hofstadter's Law.
--Hofstadter's Law
Unread 31-01-2009, 13:24
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
How accurate is the timing using floating-point precision? IEEE floating point representation isn't always 100% accurate; many times floats won't represent your value exactly as entered (e.g., 0.3 might become 0.2999...) so your times may end up slightly misrepresented internally.
Any reason as to why floating-point numbers were used instead of milli or microseconds?
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 31-01-2009, 13:28
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
The real-time timer has a precision down to microseconds i believe, but you wont have any luck searching for anything more fine than that (eg processor ticks)
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 31-01-2009, 20:49
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
You can call vxTimeBaseGet(), which is a function provided in vxLib.
IMPORT void vxTimeBaseGet (UINT32 * pTbu, UINT32 * pTbl);
This function reads the 64-bit PPC timebase, storing the upper 32 bits at pTbu and the lower 32 bits at pTbl.
The least significant bit should be worth 1/132,000,000 of a second.
It would pay to do a little experimentation with it though, to see if that number is right -- it may actually be 1/133,000,000 seconds.
In any event, it's a very high resolution 64-bit counter.
Precise enough for ya?
Are six wheels better than four? cziggy343 General Forum 36 10-01-2009 23:13
Better Than Gears? Aaron Lussier Technical Discussion 7 14-10-2003 12:20
My auto is better than yours.. lol randomperson Programming 25 07-04-2003 12:10
Kennedy better than Long Island?... soap108 Regional Competitions 6 23-03-2002 17:50
Chief Delphi 7 Picture -- better than nothing Joe Johnson Robot Showcase 7 02-03-2002 18:55
