Go to Post You will "generously donate" your game pieces into your opponent's goal. - johnr [more]
Unread 31-01-2009, 14:12
Blair Frank's Avatar
Blair Frank Blair Frank is offline
Writer and Alumnus
FRC #0852 (Athenian Robotics Collective)
Blair Frank is a jewel in the roughBlair Frank is a jewel in the roughBlair Frank is a jewel in the roughBlair Frank is a jewel in the rough
Question Joystick Issues: Your input needed!
Hey all,
We've been having problems with our Saitek ST290 joysticks (which we love) and the driver station. After a short period of use, the DS just locks up, and requires a reboot. The ST290s fit the HID spec, so the DS should be fully compatible with it. Has anyone else been having these sorts of problems?
Thanks,
Blair
Proud alumnus of Team 852, the Athenian Robotics Collective.
Pneumatics in a nutshell: Put together an elaborate series of pipes, canisters, cylinders, valves and hoses; then fill that system with highly pressurized air, and hope that it doesn't blow up in your face.
Unread 31-01-2009, 16:02
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Joystick Issues: Your input needed!
You might be having static issues. Refer to Update 7 on how to fix them.
http://usfirst.org/uploadedFiles/Team%20Update%207.pdf
-Dustin Benedict
Unread 31-01-2009, 17:02
Writer and Alumnus
Already taken care of. Is there anyone out there who has had success with the ST290s and the DS? I'm looking for positive confirmation. Thanks again!
Unread 31-01-2009, 17:14
Eric Finn's Avatar
Eric Finn Eric Finn is offline
FRC #0166 (Chop Shop)
Eric Finn has a spectacular aura aboutEric Finn has a spectacular aura about
Send a message via AIM to Eric Finn
Are you sure the problem is with the joysticks and not the DS? Have you tried with other joysticks after you started experiencing problems?
We have used the ST290s with the DS without problems, although I don't believe it we did so with the current DS firmware.
It always takes longer than you expect, even when you take into account Hofstadter's Law.
--Hofstadter's Law
Joystick Input Mapping ExarKun666 Programming 14 25-04-2008 08:41
Joystick Input calibration in software LieAfterLie Programming 3 14-02-2007 21:44
issues limiting a joystick input Unholy Programming 7 12-02-2006 19:53
S.O.A.P. Changes: Your Input Needed! Silence Scouting 12 30-01-2005 18:02
_EVERYONE'S_ input needed - read on.. :-) archiver 2000 2 23-06-2002 23:01
