Go to Post They're just dots. You can get them back. - Brandon Martus [more]
Unread 31-01-2009, 13:51
star_lancer's Avatar
star_lancer star_lancer is offline
Programming Addict
AKA: Mike Berney
FRC #2346 (CRASH)
star_lancer is a jewel in the roughstar_lancer is a jewel in the roughstar_lancer is a jewel in the rough
Send a message via AIM to star_lancer Send a message via Yahoo to star_lancer
Question Help for the Cisco linksys router?
We found the IP for the cisco linksys router that comes with the K.O.P.
We can't get to the intial IP, we can't access it through 192.168.1.1 .
Could someone please tell me what to do?
If you found anything I said helpful, please click the scales next to my post. I really appreciate those reputation points.
Team 2346 - Build, test, panic, repeat.
Unread 31-01-2009, 14:24
Bob Holmstrom Bob Holmstrom is offline
FRC #2411
Bob Holmstrom is an unknown quantity at this point
Re: Help for the Cisco linksys router?
We had a similar problem with our bridge. It would not respond to factory default settings even when reset. Linksys online support was useless.
We found the solution in the complete manual (online or on supplied CD) - pushing the "security button" on the front of the unit changes the default ip address from 192.168.1.250 to 192.168.1.251 - perhaps something similar happens with the router.
Read the full manual.
Good luck!
Bob
Unread 31-01-2009, 14:34
Programming Addict
AKA: Mike Berney
FRC #2346 (CRASH)
Talking Re: Help for the Cisco linksys router?
Thank you very much!
I just showed this to our head moderator (macmath), and he told me that he was able to connect to the router from his desktop two rooms over, so apparently the problem is with the computer we were using. Thank you ever so much again.
Wireles Router Problems mynameisbob Electrical 2 14-01-2009 22:36
Cisco Ip error setup roboengr Control System 0 08-01-2009 22:23
Bypassing router Mark Rozitis IT / Communications 17 13-12-2007 18:06
Help with VPN router Scott L. Technical Discussion 4 10-07-2006 13:33
Linksys Router Help mtaman02 Chit-Chat 10 18-03-2004 01:04
