Re: need help with autonomous!!!!!
Is the FindColor call located in the vision loop or in the teleop?
If it is in the vision loop, or otherwise running independent of the auto/tele mode, you should be able to use a global variable to store the results of the call, and you should be able to read the global in both the teleop enabled switch and in the autonomous independent subVI. This sounds quite a bit like what you've described, but it must be different as this will definitely work. If you don't find it soon, post some code. Greg McKaskle |
| Help with autonomous | MorbidAngel | General Forum | 2 | 11-12-2008 16:35 |
| we need help with PWM problem in autonomous | steve d | Programming | 7 | 03-02-2008 12:46 |
| Simulating autonomous mode - i need help!! :( | itay_ms | Programming | 5 | 21-01-2007 11:28 |
| need help with autonomous | caderader | Programming | 3 | 14-02-2005 18:25 |
| New to C but not to basic, need help on autonomous | cdennisxlx2 | Programming | 4 | 02-02-2005 03:38 |
