Go to Post After each match the pit crew gathers up the parts from the field and finds a new and interesting way to assemble them. - tsaksa [more]
Unread 31-01-2009, 15:11
naruto137 naruto137 is offline
FRC #1656
naruto137 is infamous around these partsnaruto137 is infamous around these parts
Dead cRIO??!!? HELP!!!
So um, our cRIO just died while we were driving. And now when we turn on our robot, NONE of the status lights on the cRIO turn on. Moreover, to show that its not just the LED lights that are blown out, the Ethernet lights on the cRIO do not turn one when they are connected. The cRIO is definitely getting power (first of all the power distro board is green, then we used a multimeter and found that the cRIO out on the distro board is giving 24.5V and on the receiving end of the cRIO it is also getting 24.5V. We also rechecked the WAGO connection to the cRIO and that was good as well)
Ok I will just include some other of the other catastrophic events that happened to us that could somehow, possibly be related:
1) Eth2 on our driver station did not light up ( but finally figured out that we could use a hub to plug the Laptop and Router into eth1)
2) Driver station intermittently bluescreens
3) We reimaged the cRIO and our drivers station (yes we followed all the directions
4) Oh, and the Ethernet port on the back of our laptop stops working intermittently too.
5) So after fixing all of this we were able to deploy code (but when we tried to run as startup, it could not detect a connection to the cRIO)
So is our cRIO broken? If so, how is this even possible? (We have always treated our cRIO with nothing but gracious professionalism) Is there any way we can get another cRIO ASAP – the build season will be over soon!
PLEASE HELP!!!!!
Unread 31-01-2009, 15:18
Re: Dead cRIO??!!? HELP!!!
I'm not sure exactly how things are staffed on weekends, but post to the NI forum or look for the phone number for support and returns. It is not at all common, but there is an internal fuse and a few have been blown so far this season. They will get a replacement out very fast.
Greg McKaskle
Unread 31-01-2009, 15:21
DtD's Avatar
DtD DtD is offline
I hope the watchdog starves!
AKA: Pathogen David
FRC #2410 (The Metal Mustangs (Merged from 2334, Hazmat Robotics))
DtD will become famous soon enoughDtD will become famous soon enough
For 1, 2, and 4 I would blame ESD to the Driver Station, it is extremely rensitive. Have you grounded your DS as demanded by <R82.1> in Team Update #7?
~DtD
Unread 31-01-2009, 15:51
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Probably not the problem, but if you're using Victors, check that the mounting screws are not shorting against any of the terminals. Also, try removing the cRio from the robot. You could have some sort of wierd potential on your frame issue from some sort of electrical short.
Unread 31-01-2009, 18:42
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
You should be able to get a replacement pretty quickly by contacting NI on Monday. In the meantime I'd like some more details on this issue. You mentioned the cRIO died while driving... some questions:
1) Was this actually while driving (no human contact with the robot at all), or were you downloading code or otherwise working on the robot?
2) Did anything else happen at the time of the failure (massive collision, another component failed, etc.)?
3) Have you always used the PD module to power the cRIO?
4) Have you ever "hot connected" the cRIO by plugging in a live power cable?
Thanks!
Unread 31-01-2009, 18:55
gorillamonky gorillamonky is offline
FRC #0696
gorillamonky is an unknown quantity at this point
Thanks!
if they hotwired it (hot connected) they would probably have burned the cRIO, another team had that problem
it wasn't like that when we shipped it
Unread 05-02-2009, 19:26
roboraven15's Avatar
roboraven15 roboraven15 is offline
FRC #1188 (Oaktown Crewz)
roboraven15 is an unknown quantity at this point
Send a message via AIM to roboraven15
hot wiring seems to possibly kill it, that may be our downfall as today our cRIO died, but there were other issues that could have caused it.
hard to believe the cRIO doesn't have protecters on it to avoid this, but hey maybe it is that the conection was lose on ours possibly causing the problem.
Other teams have burned up the cRIO so don't count that out.
Unread 05-02-2009, 20:30
AKA: Chris Rake
no team (Athena)
Please check the voltage input (measured at the cRIO connector). If you contact NI to get a replacement make sure you send in your broken cRIO quickly so we can take a look. Killing a cRIO is very rare, and so far has been impossible to reproduce in the lab, so when you call in please provide as many details as possible including your configuration, what was happening at the time of failure, length of time you've been using the cRIO, etc.
Unread 05-02-2009, 20:34
ironbears ironbears is offline
Alex@854
AKA: Alex
FRC #0854 (Ironbears Team 854)
ironbears is on a distinguished road
i know exactly what your problem is. when we did not change our batterys the cRIO didnot work. swap batterys
Iron Bears Team 854
Rookie Year 2002
2008 ON Xerox Creativity
2007 WAT Rockwell Automation Innovation in Control
2007 WAT Regional Finalist
2007 ON Motorola Quality
2007 ON Regional Finalist
2006 ON Motorola Quality
2005 ON RadioShack Innovation in Control Award
2005 WAT RadioShack Innovation in Control Award
2003 ON Delphi "Driving Tomorrow's Technology"
2005 The Championship Event (4/21/2005 - 4/23/2005)
2003 The Championship Event (4/10/2003 - 4/12/2003)
Unread 05-02-2009, 20:39
AKA: Chris Rake
no team (Athena)
Of course checking your battery should be high on the list. The vast majority of "buzzing" or "dead" cRIO reports have been fixed with a fresh battery
Unread 05-02-2009, 22:31
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
A recent thread here on CD said that the cRIO has an internal fuse. Some team blew that fuse, which would give the same symptoms that you are describing.
Let me try to find that thread...
EDIT: Here ya go! http://www.chiefdelphi.com/forums/sh...ad.php?t=70976
Particularly, Post 7.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 05-02-2009, 23:58
AKA: Chris Rake
no team (Athena)
Ah - and one more thing to check (and please reply with this info!) - is your cRIO electrically isolated, and if so, how?
Help Getting cRIO Feedback rholokleolke C/C++ 3 29-01-2009 17:13
Help With Our cRio DPTeam270Driver NI LabVIEW 4 25-01-2009 23:37
Help! Connecting CRIO to the Power Block RyanJK Electrical 3 07-01-2009 17:28
Little help Please (with dead reconing code) Xufer Programming 17 22-02-2004 20:12
Huron High needs help - Dead Robot kmcclary Off-Season Events 4 16-11-2001 12:36
