Go to Post When FIRST teams are as numerous and as well supported as basketball teams, we will know that our culture is preparing young people to compete in the 21 st century and we are spending our 2 million minutes wisely. - N7UJJ [more]
Unread 01-31-2009, 01:14 PM
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
"No code" each time cRIO is rebooted
Hi all,
We're having a problem loading code onto the bot with the new WPILib update. The first time the cRIO is started, and you run your user program directly, it still says "No Code". Only when you delete the program from memory and run it again does it start working. This did not happen until we updated WPILib and the cRIO/FPGA firmware.
Any one else having this issue? Any ideas?
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 01-31-2009, 04:12 PM
Maxpower57's Avatar
Maxpower57 Maxpower57 is offline
Fabuloso
AKA: Maxwell V.
FRC #2574 (RoboHuskie)
Maxpower57 will become famous soon enoughMaxpower57 will become famous soon enough
Send a message via AIM to Maxpower57
Re: "No code" each time cRIO is rebooted
Did you remember to run the image updater for your cRIO with the v11 Update?
Unread 01-31-2009, 04:32 PM
AKA: Harry Bock
FRC #1350 (Rambots)
Yes.
Unread 01-31-2009, 04:38 PM
ComradeNikolai ComradeNikolai is offline
AKA: Nicholas
FRC #2603 (Team Hornet)
ComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to behold
For clarification: are you asking if you have to use "FIRST->Undeploy" before using "FIRST->Download"? Are you asking if you have to use "FIRST->Undeploy" before running the program off of the cRIO RAM?
If the former, this is normal procedure, and a good idea even if you could get away with not undeploying; your cRIO will eventually need formatting again if you download without undeploying. Always undeploy before downloading. Also, I believe you have to undeploy to run the program with "Run" or "Debug."
I cut myself shaving with Occam's razor.
Unread 01-31-2009, 06:45 PM
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Have you tried viewing the console through the serial port? Sometimes if there is an error in the code it will not run it and you will get the no code message. View the entire boot text that it displays, the error should come up the the end if this is the case.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 02-01-2009, 02:57 AM
ExarKun666's Avatar
ExarKun666 ExarKun666 is offline
Ben Error/MC Ben/NC Ben
AKA: Ben Kellogg
FRC #2429 (LCEC)
ExarKun666 is an unknown quantity at this point
Send a message via AIM to ExarKun666 Send a message via MSN to ExarKun666 Send a message via Yahoo to ExarKun666
Hi all,
our team has had this problem, what we did was (if tethered) make sure you are downloading the .out file, if you are go to FIRST then click download, if no progress bar comes up there must be setting that still needs to be changed. If the progress bar does come up then restart the bot, first it says No Comms then No Code, just be patient, it takes ours about 4 min or less (depending) until it says the voltage of the battery. Hope this helps
Ben Kellogg
Team Sites: [LCEC Site] [FRC/FLL Site] [LCEC Blog]
Unread 02-01-2009, 12:26 PM
AKA: Harry Bock
FRC #1350 (Rambots)
No, we're using just the Run dialog, where the program is loaded directly into memory. Our code loads and shows up in the Remote Systems panel, but the driver station still says "No Code". After deleting the code from the panel (right-click 'project.out' and click Delete) and re-running it (again directly from memory), it works fine until you reboot the cRIO.
It's not a huge problem - it only takes about 10 seconds do load-unload-load and get it working, but it is a little annoying.
Unread 02-01-2009, 12:46 PM
Bharat Nain's Avatar
Create a new default project and download it.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 02-01-2009, 01:46 PM
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
are you clicking Run or Run Kernel Task? you have to Run Kernel Task W/ the proper setup
Watchdog.Kill();
Unread 02-01-2009, 04:56 PM
Analog's Avatar
Analog Analog is offline
AKA: Bob Most
FRC #2619 (The Charge)
Analog will become famous soon enoughAnalog will become famous soon enough
Use the console via RS-232
if you've reflashed, then make sure you do a full power down.
cRio losing connection when "run as startup" mgurgol Programming 2 01-12-2009 12:18 PM
Team 1261 - cRIO on 2008 "Longshot" Tanner Robot Showcase 2 12-31-2008 12:44 PM
"Battery: No Code" after uploading .out file to cRIO knine143 FRC Control System 1 12-20-2008 10:14 PM
Getting two Vex controllers to "talk" to each other thefro526 Programming 1 05-28-2007 11:59 AM
Coolist "bot" in each division Michael King Championship Event 46 04-21-2003 06:20 PM
