Re: PWM maximum outputs
You can get the actual 8-bit numbers by delving slightly into the Motor Open vi's and the Servo Open vi. The Victors are something like 40 to 210 with a center around 133. The Jaguars are something like 3 to 252, with a center at 127. Servos are 11 to 240 or so. The numbers that define the range are the minNegativePWM and maxPositivePWM values in the PWM reference cluster.
| Use of PWM outputs 13-16 via WPILib | sfs | Programming | 1 | 29-01-2008 09:47 |
| Problem with PWM outputs on RC | Adam Richards | Control System | 1 | 20-02-2007 06:37 |
| pwm outputs vs. joystick y-axis | stephenthe1 | Programming | 4 | 01-12-2004 17:29 |
| Trouble with pwm outputs | misterikkit | Programming | 16 | 17-01-2004 10:56 |
| relay and pwm outputs | nick_champ_2 | Electrical | 1 | 31-01-2003 13:08 |
