Go to Post All I know is I have fun building a robot, and I have fun competing with it. If I get an award, I'm happy. If I don't, then too bad. Either way, I'm coming back next year. - Tom Bottiglieri [more]
Unread 31-01-2009, 19:24
pinballwizard96's Avatar
pinballwizard96 pinballwizard96 is offline
Ludologist, audiophile, etc
FRC #3021 (The Caiman Agents)
pinballwizard96 is an unknown quantity at this point
Non-Arcade Drive causes problems in Autonomous...
I deployed the default FRC cRIO project correctly and noticed that both drive motors were now controlled by one joystick. When I switched to Autonomous mode, the default program ran as expected EXCEPT...only 1 motor changed directions - the other one ran in the same direction for the duration of the program. I tried switching the connectors, and the OTHER motor experienced the problem while the 1st one corrected itself. Could this be related to the speed controller, or is the autonomous program intended to switch the direction of only 1 motor?
Thanks in advance
pinballwizard96
"The Enrichment Center is committed to the well being of all participants. Cake and grief counseling will be available at the conclusion of the test. Thank you for helping us help you help us all." -Portal
http://www.youtube.com/watch?v=VnqpOFcBiMM
Adding non drive motors in Advanced Framwork ffej NI LabVIEW 11 01-02-2009 20:12
Arcade/Tank Drive Malfunction piedmont Programming 2 19-01-2009 17:37
Non-camera servos in Autonomous Vashts6583 Programming 8 18-02-2007 12:31
Arcade Drive Anfony VEX 4 08-11-2006 19:46
vex programming arcade drive setting Michael Leicht FIRST Tech Challenge 3 17-10-2005 21:26
