Go to Post Those kids are different! They seem more mature, respectful, and intelligent than most adults. They can actually think instead of just spitting out facts. They are obviously getting a real education. - Amber H. [more]
Unread 31-01-2009, 20:10
Abra Cadabra IV's Avatar
Abra Cadabra IV Abra Cadabra IV is offline
Still spinning in circles
AKA: Katy W.
FRC #2429 (Blockheads), FTC #25 (Rock-n-Roll Robots)
Abra Cadabra IV is just really niceAbra Cadabra IV is just really niceAbra Cadabra IV is just really niceAbra Cadabra IV is just really niceAbra Cadabra IV is just really nice
[FTC]: LabView servo issue
My team's almost done with programming our robot in LabView and we've hit some bizarre snags.
Our bot has an arm, a pivoting bucket, and a claw. Our arm is controlled by two motors, our bucket is controlled by two servos (y-cabled together and facing the same direction), and our claw is controlled by one servo opening/closing the claw and one rotating the claw itself. We have code installed that, if a button is pressed, will move our arm to a certain location (through use of encoders) and will also rotate the bucket to a certain position. We have four buttons programmed like this, to move the arm and bucket to four distinct positions.
However, when we do this:
-Our motors often do not stop at the same time and one will keep going for 1/4 to 1/2 rotation longer
-The servos on our bucket twitch back and forth uncontrollably and are very slow in moving to the position we tell them to
-The servos on the claw also move when the buttons are pressed, even though they are most definitely NOT called in the program
What could be causing this? We've downloaded all the updates. Our servos and motors are running in the same direction and we've confirmed that they're not fighting each other. It's truly confusing.
Also, do the other programming languages have these same problems or is it just LabView?
Proud alumna of:
FRC Team 2429 - Blockheads
and
FTC Team 25 - Rock 'n' Roll Robots
[FTC]: Tips page on using FTC Encoders with LabVIEW PhilBot FIRST Tech Challenge 7 27-01-2009 14:00
[FTC]: [FTC]: RobotC Template Problem (causing an FMS issue) and Potential Servo Prob PackersFan FIRST Tech Challenge 11 26-01-2009 21:25
[FTC]: First problem with FTC and LabView.....? PhilBot FIRST Tech Challenge 5 07-11-2008 10:36
[FTC]: FTC Controller Station Connectivity (Bluetooth and USB) Issue jbbjjbt FIRST Tech Challenge 6 05-11-2008 11:49
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
