Go to Post Consider that the 12V from your robot isn't any different from the 12V from your car's cigarette lighter. (Err... sorry... that's "power port" these days, thank goodness.) - dtengineering [more]
Unread 28-01-2009, 22:25
KNZ1030 KNZ1030 is offline
FRC #2158
KNZ1030 is an unknown quantity at this point
p60 gearbox disassembly
Chief delphiers-
My team and I recently ordered a p60 banebox gearbox and cannot figure out how to get it apart to grease the inside. Any pointers would be greatly appreciated.
Thanks!
Unread 28-01-2009, 22:32
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: p60 gearbox disassembly
All you do is undo the 4 bolts through the face. Banebots said that it might be a tight fit and that you just pull until it separates after you have removed the bolts.
We just got 4 in today and hopefully we will start testing them in the next few days. So far they look exponentially better than the 36/42mm banebots
Mentor 2415
Unread 31-01-2009, 20:36
Ceal Craig's Avatar
Ceal Craig Ceal Craig is offline
Ceal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of light
We are looking at using the P60 gearbox with the Mabuchi motor in the KOP or possibly the Fisher-price motor itself from the KOP (without its gearbox).
Is that correct? we are a little confused right now whether both motors will work with it?
Cecilia (Ceal) D. Craig
Retired Mechanical Engineer (BSME: The Ohio State University; MS CalState Fullerton)
PhD in Education Student Walden University
FRC Mentor: 2003 - 2009
Treasurer WRRF BOD: Western Region Robotics Forum
Unread 31-01-2009, 21:17
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Yes, you can use either the rs545 motor or the fisher price motor with the P60 gearbox. The shaft on the fisher price motor does need to be cut a little shorter, but other than that it works great.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 02-02-2009, 11:07
Ceal Craig's Avatar
Thanks so much -- appreciate the quick reply!
P60 planetaries gearboxes Rosiebotboss Motors 25 24-05-2009 00:57
Gearbox pt 2 bobdahaxor Technical Discussion 14 22-12-2007 11:24
Gearbox bobdahaxor Technical Discussion 1 13-12-2007 19:34
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
Gearbox ZACH P. Motors 4 09-02-2003 20:14
