Go to Post It is usually the simple things that get you. - Andy Brockway [more]
Unread 31-01-2009, 14:05
DillonMartine DillonMartine is offline
FRC #0417
DillonMartine is an unknown quantity at this point
Setting the speed on a jaguar in C++
Hello all,
When setting the speed of a jaguar
To drive our robot we are using one jaguar. When the joystick y axis is move above neutral we plan to have the speed of the jaguar increase untill it reaches max. once its at max, we want the motor to continue to move untill the joystick is returned to neutral.
if(stickc->GetY()> 0 && driveflagf==0){
drive->Set(0);
speed = 0;
for(int counter=0;counter<=5;counter++)
speed = speed +.2;
drive->Set(speed);
Wait(1);
driveflagf = 1;}
if (stickc->GetY()>0 && driveflagf==1){
drive->Set(1);
if (stickc->GetY()== 0){
drive->Set(0);
Would the above code accomplish this? we have tested just setting the speed of a jaguar to max by hitting a button, but the jaguar seems to only turn on for a second..
Any Ideas?
Unread 31-01-2009, 21:32
programMORT11
Posts: n/a
Re: Setting the speed on a jaguar in C++
have you made sure that driveflagf is a static variable?
Unread 31-01-2009, 22:31
FRC #0417
Yes its static.. Technically the code should work as intended no?
Unread 01-02-2009, 11:26
elcron elcron is offline
Programmer
FRC #0348
elcron is an unknown quantity at this point
Try holding down the button.
pic: Jaguar Speed Controller Padre_Vez Extra Discussion 15 31-01-2009 14:41
Motor speed sensing with the Jaguar motor controller? mminutto FRC Control System 5 13-01-2009 18:13
Brake/Coast setting for speed controller cabbagekid2 Control System 0 16-02-2005 16:54
Brake/Coast setting for speed controller cabbagekid2 Electrical 0 16-02-2005 16:54
Speed Controller brake/coast setting steven114 Electrical 21 03-03-2004 13:05
