Go to Post Ice cream is an iterative process. - JVN [more]
  #31   Spotlight this post!
Unread 30-01-2009, 13:55
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Re: 1726 progress - week 4
what do you use to turn the turret; servo, motor, or is connected right to the robot's frame
Is now an engineer thanks to FIRST.
  #32   Spotlight this post!
Unread 30-01-2009, 14:00
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Their turret is powered by a Banebots RS545 through a 36mm 64:1 transmission. It has a V-belt pulley on the output that drives their "turret base" which is actually a very large V-belt pulley.
Pictures can be found here:
http://photos.project1726.org/thumbn...lbum=34&page=1
Specifically the turret motor and pulleys:
http://photos.project1726.org/displa...lbum=34&pos=15
  #33   Spotlight this post!
Unread 30-01-2009, 18:20
JoeArnold's Avatar
JoeArnold JoeArnold is offline
FRC #1361
JoeArnold will become famous soon enough
Nice.
  #34   Spotlight this post!
Unread 30-01-2009, 23:12
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
As usual, Awesome! Just Awesome! I wish I were you! Way to go!
Faridodin "Fredi" Lajvardi KD7WKD
  #35   Spotlight this post!
Unread 31-01-2009, 00:56
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Thanks for all the feedback!
I sure hope the programmers get the robot for the last week this year, that would be a first! Although we're mostly still waiting for the rest of the robot to be "adjusted" before continuing
So we basically did a small distance test today with PWM values and distance; we managed to get very consistent shots considering the variety of conditions our balls are in. Plugged into a jaguar, here are the basic results:
output(0to1)   Distance
.3-.4          0-1ft
.4-.5          2ft
.5-.6          3-4ft
.6-.7          6-7ft
.7-.8          8-9ft
.8-.9          9-10ft
.9-1           9-10ft
Not very exact (off the top of my head, I'm pretty sure it's right) but it is much more accurate than it sounds. We'll map this out and create some relationship between the motor speed and distance. We're planning on using the height or size of the target as the distance calculator. If we have time we'll add some form of revolution counter to the shooter for more a more determinate angular speed than PWM values (3500rpm is kinda fast for an encoder... I saw 111 used a reflection sensor on their 2006 robot in the "Behind the Design" book? perhaps that'll work...).
EDIT: I have been reminded to mention that the distance calculated was between the front of the robot and the back of the trailer (space between the robot and target trailer). Which may or may not be important
  #36   Spotlight this post!
Unread 31-01-2009, 01:02
CraigHickman
Posts: n/a
A good way to sense speed on a high velocity wheel like that would be to put a small magnet into the wheel (drill a small hole and put an iron nail in, slice the head off), and set up a hall effects sensor. Each rotation should be VERY noticeable, so you should be able to get some speeds out of that....
  #37   Spotlight this post!
Unread 31-01-2009, 07:06
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Good looking robot and a real nice shooter.
I have one question. Will it track, and score, a moving target?
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
  #38   Spotlight this post!
Unread 31-01-2009, 09:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We're working on that. Still need to get several other things squared away first, but scoring on a moving target is one of our prime goals, so we will surely try our best to make it work. Our first test of this ability was kind of disappointing.
  #39   Spotlight this post!
Unread 31-01-2009, 13:08
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
What size roller did you use? What is the material around the roller?
Doug Leppard
  #40   Spotlight this post!
Unread 31-01-2009, 14:18
AHS1599's Avatar
AHS1599 AHS1599 is offline
Parent/Mentor
FRC #1599 (Techromancers)
Team Role: Parent
AHS1599 is an unknown quantity at this point
Thumbs up Re: 1726 progress - week 4
That bot looks really "screwy" Nice job!!
2007 NASA/VCU Regional Semi-finalist
  #41   Spotlight this post!
Unread 31-01-2009, 21:43
MrForbes's Avatar
AKA: Jim
The shooter and helix rollers are 4" ABS. The shooter roller has gum roughtop conveyor belting (wheel tread), the helix roller has shelf liner from Walmart, attached with aluminum strips to hold it on.
here's the only picture I could find just now...and we redid this, the flaps are each only about an inch wide now, instead of 2".
It might have some wear issues, so we may be looking for something else to use?
  #42   Spotlight this post!
Unread 31-01-2009, 21:59
Thanks that was helpful. Ours is a 5 inch running at 2500 rpm. It is not working yet other than the proto type. So these numbers give us a hint how we might be doing.
Doug Leppard
  #43   Spotlight this post!
Unread 31-01-2009, 22:01
MrForbes's Avatar
AKA: Jim
The shooter is set up with chain drive, 15 tooth motor to 22 tooth roller, from the CIM. The helix is driven by an AM Stackerbox with a CIM on it (s_forbes from our team seems to have come up with the idea of putting the CIM on that transmission, and AM put it into production), I think it's 3.57:1 ratio, driving a 9 tooth sprocket, and a 22 tooth on the roller.
  #44   Spotlight this post!
Unread 31-01-2009, 22:10
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Very impressive!
Looks a lot like our mechanisms (helix and shooter are very very similar), except you guys are testing and debugging and we're staring at a pretty SolidWorks model yet to be built...
Manoel Flores da Cunha
Brazilian Machine
Team # 383
  #45   Spotlight this post!
Unread 01-02-2009, 13:32
RandomStyuff RandomStyuff is offline
FRC #2212 (Spikes)
RandomStyuff is a jewel in the roughRandomStyuff is a jewel in the roughRandomStyuff is a jewel in the roughRandomStyuff is a jewel in the rough
Wow, extremely impresive!
How did you make the CIM motor move by angle?
1726 Beginning Week Three GUI Robot Showcase 26 21-01-2009 15:19
pic: 1726 week 4 TheOtherGuy Extra Discussion 29 04-02-2008 00:36
pic: 1726 Ramp Progress s_forbes Extra Discussion 6 19-02-2007 01:14
pic: Real Pic of Team 1726 MegaMaid Progress yodameister Extra Discussion 4 12-02-2006 13:23
