Team Color Identification
Hello all,
As far as I understand, we should receive an indicator of what team we're on from the competition port on the Driver's Station. Does anyone know how to access this in our programming code or if this is even possible? (we're using c++) Thanks, Sarah Edit: I found it, but I will leave this posted as a refference for other teams. The Driver Station class contains an enumerated variable called "Alliance" with the values kRed, kBlue, and kInvalid. Last edited by legotech25 : 01-31-2009 at 01:19 PM. |
Re: Team Color Identification
You can get your team color by using the DriverStation class:
DriverStation ds; if(ds.GetAlliance() == DriverStation::kRed) // do something else if(ds.GetAlliance() == DriverStation::kBlue) // do something else else // WPI lib is broken as usual |
Anyone know a way to trick the robot into thinking it is on red or blue for testing purposes?
~DtD |
I wouldn't play with the competition port at all, I would just say use a switch, and see if receiving it from the DS actually works at competition
if you know about classes, create a simple class
(this probably has bugs in it, but illustrates the point) Code:
class FakeDriverStation :private DriverStation
Alliance GetAlliance(){return DriverStation::kRed;}
//Code
//more code
//DriverStation DS;//make sure to uncomment this
FakeDriverStation DS;//and comment this before competition
switch(DS.GetAlliance())
| Does the Trackball Color Match your team Color??? | ZInventor | Kit & Additional Hardware | 14 | 03-07-2008 08:09 PM |
| Team Identification on Robot | 1337pcgamer | Rules/Strategy | 1 | 01-27-2006 05:59 PM |
| Determining Team Color | larwilliams | Programming | 4 | 03-30-2005 07:41 AM |
| Team Color | DrWorm | Control System | 1 | 02-02-2004 07:02 PM |
| Team Color LED's | Phil_Lutz | Technical Discussion | 4 | 01-18-2004 07:56 PM |
