Go to Post I'm probably going to make somebody feel old right now... - NorviewsVeteran [more]
Unread 01-27-2009, 06:49 PM
Electricia 1599's Avatar
Electricia 1599 Electricia 1599 is offline
2nd Solutions E-Cycle Program Head
AKA: Devyn McIver
FRC #1599 (Atlee Robotics)
Electricia 1599 is an unknown quantity at this point
Send a message via AIM to Electricia 1599 Send a message via Yahoo to Electricia 1599
Smile robot 1599 youtube videos
check out our videos of atlee 1599. i will be posting up some more! this might also help some teams as well.
http://www.youtube.com/profile?user=...ty&view=videos
Unread 01-27-2009, 07:34 PM
Rich Wong Rich Wong is offline
NYC FIRST Planning Committee Member
no team (NYC FIRST)
Rich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond repute
Send a message via AIM to Rich Wong
Re: robot 1599 youtube videos
Very nice video!
Thank you for sharing this.
I see many of the challenges caused by this year's new floor.
popularis de ob instinctus agnitionis scientia technologia
Home website: www.nycnjfirst.org
Member of NEMO & e^(i*pi)+1 Fraternity.
Member of Friends of Robots
Member of NYCFIRST Planning Committee
Unread 01-27-2009, 08:01 PM
Ian S. Ian S. is offline
FRC #1522 (D.O.T.M Robotics)
Ian S. is an unknown quantity at this point
Send a message via AIM to Ian S. Send a message via Yahoo to Ian S.
I like the drive train setup! How many wheels are on that bot?
Hopefully HHS and Atlee can meet on a Saturday to test out some bot v. bot action pretty soon, It will be interesting to see.
D.O.T.M - Defenders of the Multiverse
2006 VCU Regional Finalists (thanks to team 345 & 384)
2008 VCU Regional Champions (thanks to team 345 & 1086)
Unread 01-27-2009, 11:20 PM
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Looks like 10 wheels.
Do the double wheels actually help at all with traction, or are they just for stability? Because friction force is dependent on an inverse relationship between coefficient of friction and normal force, if you add more wheels, adding to the over all friction coefficient, you're decreasing the normal force on each wheel by the same amount, so the effects cancel and you end up with the same amount of friction force. The reason more wheels are used for more traction is mainly an issue of distributing the force evenly to reduce the event of too much load on one particular part of the robot, which CAN result in slipping. Not too much problem with distribution this year because there's very little back-force on the wheels. Might as well use fewer wheels and use that spare weight to put some small steel bars a little closer to the floor.
By the way, if I'm wrong, please do correct me.
Unread 01-28-2009, 08:34 AM
AHS1599's Avatar
AHS1599 AHS1599 is offline
Parent/Mentor
FRC #1599 (Techromancers)
Team Role: Parent
AHS1599 is an unknown quantity at this point
Daltore, I believe your theory is correct, however the design team wanted to test this configuration (2 motors, 8 drive wheels and 2 passive front wheels) with that in mind. The results were surprisingly good. Our first try the week before was using 4 wheels in 4WD configuration and it didn't seem to have nearly the grip, speed or maneuverability that this prototype has.
In the three years that I have been a parent/mentor with the team, this is the first time we have been able to run prototypes this early in the build and it seems to be paying off well!
As a side note, Scott who owns Sonic Tools has been gracious enough to convince his landlord to donate unrented space in this warehouse for the teams to have a practice field, as well as funding the materials for construction himself. This field is open to any teams that can make it to the site just outside of Richmond, VA. Saturdays usually have a couple of teams, but you can contact Scott for other possible times. His website is http://www.soniclp.com/home.html Thanks Scott!!
2007 NASA/VCU Regional Semi-finalist
Unread 01-28-2009, 11:44 AM
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
It looks like you guys have a nice drive train, our team has a similiar base design with an almost U shape, so I'm guessing there's going to be a conveyer belt or other pick-up mechanism there. The only big difference is we settled with just a traditional 4-inline wheels, inorder to have more weight resting on each individual wheel.
Unread 01-29-2009, 10:33 AM
AKA: Devyn McIver
Smile Re: robot 1599 youtube videos
10 wheels im pretty sure, we were origionally going to use 12 wheels
it would be great to work with hanovers team. i think we need to help each other more in the long run than be rival schools. i actually go to atlee but have classes for 4 years at hanover for electronics.
Unread 01-29-2009, 10:35 AM
AKA: Devyn McIver
well your argument is plausable and we thought the same thing at first but we tested it out and it does help with traction
Unread 01-29-2009, 11:45 AM
organman42's Avatar
organman42 organman42 is offline
AKA: Jeff
FRC #1073 (The Force Team)
organman42 is an unknown quantity at this point
The robot looks good. It looked like you have more traction than I would have expected.
"I have a different vision of leadership. A leadership is someone who brings people together."
Unread 01-29-2009, 01:15 PM
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I'm a bit curious about the tests you performed that led to this conclusion. Were the weights of the "single wheel" and "dual wheel" robots the same (ie did you account for the weight of the extra wheels?). Were all wheels powered in both configurations? Was the arrangement of wheels the same? Were the wheels checked for any surface changes in between the two configurations?
Unread 01-29-2009, 04:06 PM
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
I think this should be in robot showcase. I don't beleive extra wheels give more traction if that's your intention, because traction is affected by mass and coefficient of friction. The friction is fixed at .05 however, you could change the mass. In the end surface area is pointless.
Unread 01-31-2009, 10:55 PM
AKA: Devyn McIver
yes to all we were very specific when doing the tests
Old FIRST (and US FIRST) videos posted on Youtube Andy Baker General Forum 53 07-21-2010 11:45 PM
1629 (GaCo) Robot Videos PhilBot Robot Showcase 9 02-26-2008 09:38 AM
DARPA Robot Videos ChuckDickerson Championship Event 14 04-20-2007 04:37 PM
Congrats Team 1599 Athleticgirl389 Thanks and/or Congrats 0 03-16-2007 05:37 PM
Videos of Team 1636's Robot(YouTube) LightWaves1636 Robot Showcase 4 02-28-2007 12:07 AM
