#13
Re: two color tracking code
If the know and slider move the servos, the code should move them too. There is a switch on the front panel to change from camera view to servo control.
Do the servos move but aren't moving correctly? If that is the case, you may have built the gimbal different than the one the SW was written for. Disconnect them one at a time and see if the movement makes sense for either dimension. When you find a dimension that is backwards, you can open the Gimbal control and negate the proportion for that dimension. If you don't get it working, please be more detailed. It shouldn't take this many posts to fix the problem. Greg McKaskle |
| Multiple Targets in "LabVIEW Sample two-color target tracking code" | markulrich | NI LabVIEW | 7 | 29-01-2009 11:52 |
| Two Color Tracking Demo | Bharat Nain | Programming | 43 | 25-01-2009 18:58 |
| Two color tracking problem | nadavsen2 | Programming | 3 | 19-01-2009 14:44 |
| 449's code for tracking two colors | jacobhurwitz | NI LabVIEW | 4 | 15-01-2009 21:19 |
| Tracking Color? | haywirerobotics | Programming | 0 | 14-01-2006 13:55 |
