Go to Post Being called coach for the first time by some of my team. My dad was a football player and when I told him that story he teared up a bit. Me? A Coach? - MysterE [more]
Unread 27-01-2009, 01:21
PWHSrobotics PWHSrobotics is offline
PWHSrobotics is an unknown quantity at this point
Ultrasonic Sensors
Hello, sorry if this has been answered before.
Are any other teams using ultrasonic sensors to sense the other robots on the field, and are you having any success?
What sensors work with the Labview VI's given to us?
Unread 27-01-2009, 06:39
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Re: Ultrasonic Sensors
Last year I was looking for some ultrasonic range finders for our bot and I through a response on chiefdelphi the LV-MaxSonar was recommended to me. It outputs the range to an object in several ways including serial, analog voltage, and pulse width. Of these methods I would probably choose the analog voltage since you only need to multiply this by a constant to resolve the range. The distance calculation is already done for you!
here is the website for the sensor.
http://www.maxbotix.com/
Hope this helps!
Unread 27-01-2009, 09:48
ok, and it works with this years labview software VI's, and easily hooks into the hardware of this years control system? (our team was only in FRC in 2006, when you had to do everything in c++, so we don't know really what was used last year)
Unread 27-01-2009, 11:34
ScottW of MaxBo ScottW of MaxBo is offline
ScottW of MaxBo is a glorious beacon of lightScottW of MaxBo is a glorious beacon of lightScottW of MaxBo is a glorious beacon of lightScottW of MaxBo is a glorious beacon of lightScottW of MaxBo is a glorious beacon of lightScottW of MaxBo is a glorious beacon of light
Dear PWHSrobotics,
Yes, the MaxSonar sensors will work. Please see thread below regarding use of MaxBotix Sensors.
http://www.chiefdelphi.com/forums/sh...819#post808819
If you have any questions, please let me know.
Best regards,
Scott Wielenberg
Technical Support & Sales
of MaxBotix Inc.
Phone: (218) 764-2489 Ext. 2
Fax: (218) 764-2194
Email: scott@maxbotix.com
Web: www.maxbotix.com
Unread 31-01-2009, 23:26
can people tell me how accurate these things are? (inches, feet, cm, etc)
I need to know to finish my proposal to the team and accuracy could help convince some of the people on the team. 100$ a piece is a bit pricey for my team.
Thankyou in advance for your help
Unread 31-01-2009, 23:38
You don't need the $100 waterproof model.
FIRST robotics teams use the $30 models.
They are accurate to inches.
Unread 31-01-2009, 23:41
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
You're looking at the wrong ultrasonic sensors I think.
Scroll down the page a bit. They go from $100 (some new one that I haven't seen yet) to $30, the one I have seen.
Also... here's my experience from them. Being a total newbie programmer, I tried to work on autonomous for IRI this year. If anyone was at IRI and on the field while Team Fusion was out there, I'm sorry for any damage we did.
That should pretty much sum up my experience with them. I did find that the readings were really good though. I just couldn't get them to work for me properly.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 01-02-2009, 00:19
seems that within one inch is good enough, my question is, if our target is at an angle, will it return the distancefrom that angle to the object, or will it just give me the shortest distance , or what?
Also, there are more than 1 at 30bucks, any one do better for FIRST purposes than others?
Unread 01-02-2009, 04:46
FRC #2477
no, they wont give you and angular info. They will only give you the shortest distance read within the beam pattern. If you want to get angle info you can use two of these sensors (they will need to sound at different times to not get them confused) and by knowing the distance between the two sensors you can use trig to get angle info. We are thinking about using the camera to track the goal and then use the sonar to range. might be more accurate than the camera ranging.
Unread 01-02-2009, 10:07
ok, my only worry, is with that beam width, it will cause me to get scewed results if my target is at an angle.
Thanks for all the helf.
Unread 05-02-2009, 11:30
mikeqfl's Avatar
mikeqfl mikeqfl is offline
FRC #0832 (Chimera)
mikeqfl is an unknown quantity at this point
Has anyone tried using the camera for ranging information? Is there a canned routine in Labview to do that? Any feedback on how accurate it is? We are using a camera to track the the opposing trailer and need range feedback to feed to our shooting mechanism. We almost have all of the mechanical stuff worked out, time to program and try to make it all work now. Nothing like saving the best for last.
Unread 05-02-2009, 11:38
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
If you look at the tracking example, some of the outputs from the code include blob area and min and max X and Y values. You could correlate the area to distance, but that won't be very accurate. You could take the difference in Ymax and Ymin which should correlate very well to perceived height, which correlates very well to distance...
Former Mentor Team 1771
Former mentor Team 4509
Unread 05-02-2009, 12:39
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Please be aware there are some issues using the Analog output of the Maxbotix sensor.
#1 There is a "bump" if you have a large change in distance. The sensor will overshoot the actual distance and then ramp back down to the correct one. You can filter this using averaging, but it will slow the response.
#2 Don't expect to be able to use these to track or range other robots. They respond too slowly. Last year, at full speed using these sensors, we had to stop when the sensor hit 48 inches because of the response time. If we did so, it was actually hitting the brakes at about 18 inches, and stopping with 3 or 4 inches to spare.
What you CAN do with these is use them for collision detection. You can also aim them at a continuing obstruction. For instance - aim it a wall that you're traveling next to. You can keep track of how close you are to it.
I do not know if the other outputs of the Maxbotix will exhibit the same behavior. I'd suggest purchasing one and working with it before you decide it will solve your problems.
For static ranging, however, they are VERY accurate. Consistently within less that an inch.
Unread 07-02-2009, 11:23
We got our sensors today, but have a question
- How are other teams hooking up the sensors to work with the built in Ultrasonic VI's given to us in labview?
Unread 09-02-2009, 07:38
any help or a link to a topic that this was already answered in would be much appreciated
WPILib and Ultrasonic sensors DanielR. Programming 7 18-06-2008 17:31
Parallax and Maxbotix ultrasonic sensors Lucretius Programming 5 20-02-2008 14:34
Ultrasonic sensors on digital ports 3-6 problems wt200999 Programming 14 13-02-2008 08:13
Ultrasonic range sensors for Vex Robot OneCoolDude Programming 1 01-12-2007 09:22
can we use ultrasonic sensors? GMKlenklen Electrical 20 15-01-2007 14:34
