Go to Post When we find bugs at work, we don't ask "who wrote that section of code?" We ask "Who is the best, most knowledgeable person to work on fixing this bug?" - Jon Stratis [more]
Unread 01-02-2009, 00:41
EricH EricH is online now
Re: For those who are skeptical about propellers - Team 2526
Originally Posted by zrop View Post
safety cage we are going to use is designed to keep balls outs rather than keeping blade shrapnel in.
The inspectors will be looking for both. One piece of prop shrapnel gets through, and <S01> is probably going to be called. Then you have to remove both.
Let's say those are 9" blades going at 7000 RPM. That's C=pi*d=pi*9=28.26" per revolution. That's about a 2' circumference (rounded down to emphasize the need for protection here). So, the tips of that prop are traveling at 7000RPM=116.7RPS over a 2' circle. That's a tangential speed of 233.3 feet per second--or about 4 FRC fields in one second. If a tip breaks off at that speed, you WILL get a safety violation if it leaves the robot! And, if I were the head ref, I'd make you either remove the props or add protection to the cage. Play it safe and add material now.
Edit: I just saw this: http://www.chiefdelphi.com/forums/sh...049#post812049
I would consider this, or something similar, much safer than your current setup.
Fans/Propellers - Are you doing them? Greg Peshek General Forum 15 06-02-2009 19:50
To those who are officers/admins here... synth3tk General Forum 3 26-09-2008 07:06
For those who lack dedication... Pi Is Exactly 3 Regional Competitions 19 09-02-2005 21:26
Some good humour for those who are bored. Frank(Aflak) Chit-Chat 0 09-12-2003 19:11
For those who were wondering... Nate Smith Championship Event 2 22-04-2002 17:25
