Go to Post ....a red-light-of-death. - Kevin Watson [more]
Unread 31-01-2009, 20:17
zrop zrop is offline
FRC #2526
zrop has a spectacular aura aboutzrop has a spectacular aura aboutzrop has a spectacular aura about
For those who are skeptical about propellers - Team 2526
The props both spin at about 7000 rpm, but they haven't been properly calibrated yet, so we may get quite a bit more power out of them.
Videos:
http://www.youtube.com/watch?v=mlUPGUfgrHo#
http://www.youtube.com/watch?v=crKvPEwvf-U
And for those safety nazis -- why yes we do have a safety cage for it
Unread 01-02-2009, 00:14
EricH EricH is online now
Re: For those who are skeptical about propellers - Team 2526
What type of props are those? They look like 9"x something. Are they balanced? If not, I can tell you how to balance a prop.
Also, I'm not quite sure that that cage is going to be enough. I'd put another layer on on top or underneath so that the area of each open area is divided into four areas--if the props do explode, I'm pretty sure they could get through the pictured version. Reducing the open area will also reduce the risks.
Unread 01-02-2009, 00:22
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Wow that totally is a unique and different propulsion system! I cant wait to see that in actual competition!
I would tend to agree with Eric though, I'd add some more protection to that cage. The cage will protect from reaching hands, but if those props were to ever break, (and going 7000 rpm, they very well might) you dont want blades going flying... I'm not a safety Nazi, I just like being safe.
Overall though, Awesome!
Unread 01-02-2009, 00:28
FRC #2526
safety cage we are going to use is designed to keep balls outs rather than keeping blade shrapnel in.
Unread 01-02-2009, 00:30
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Cool.
What are the pegs on your rollers? What's the diameter of them? If they are too small, you might have inspection problems.
Unread 01-02-2009, 00:41
The inspectors will be looking for both. One piece of prop shrapnel gets through, and <S01> is probably going to be called. Then you have to remove both.
Let's say those are 9" blades going at 7000 RPM. That's C=pi*d=pi*9=28.26" per revolution. That's about a 2' circumference (rounded down to emphasize the need for protection here). So, the tips of that prop are traveling at 7000RPM=116.7RPS over a 2' circle. That's a tangential speed of 233.3 feet per second--or about 4 FRC fields in one second. If a tip breaks off at that speed, you WILL get a safety violation if it leaves the robot! And, if I were the head ref, I'd make you either remove the props or add protection to the cage. Play it safe and add material now.
Edit: I just saw this: http://www.chiefdelphi.com/forums/sh...049#post812049
I would consider this, or something similar, much safer than your current setup.
Unread 01-02-2009, 00:43
Woodworker88 Woodworker88 is offline
Shop Rat
AKA: Michael Fagan
FRC #0190 (Gompei and the H.E.R.D), FRC #0114 (Eagle Strike)
Woodworker88 is a jewel in the roughWoodworker88 is a jewel in the roughWoodworker88 is a jewel in the roughWoodworker88 is a jewel in the rough
Nice work, looks like you put some thought into the design. Good use of model airplane props.
Are you worried that having the props mounted in a biased configuration (not dead-center on the robot) will tend to make the robot turn or move awkwardly? I assume you offset them to make room for a ball-handling system. Will the airflow pass through the ball system or will you reverse the rotation to reverse the direction of the robot?
On a separate note, have you checked the metal hardware on your collector to make sure it's not going to rip up the balls? Looks iffy to me.
2005-2008 FRC Team 114 (Los Altos, CA) Lead Machinist and Shop Manager
2009-Present FRC Team 190 (Worcester, MA) Lab Manager
Worcester Polytechnic, Mechanical Engineering 2012
2009 Boston Regional
GM Industrial Design, Regional Champs (thanks 61 and 1099)
"Do or do not. There is no try." -Yoda
Unread 01-02-2009, 00:44
run the trap!!!
Team Role: Human Player
What you should do is put them up high, so they will both propel your bot and blow-away balls.
If it can move a 120 lb. bot it should be able to deflect a few rocks
-Philip J. Fry
Unread 01-02-2009, 00:49
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
Sadly that hasn't worked with the tests our team has doen, the porous nature of the ball's geometry tends to not move it at all. Our tests were all done with a 22" blade with a 3D-10A pitch blade that was moving a lot of air at a 1:1 ratio from a CIM. YMMV.
Looking good guys, keep it up.
-Greg
Unread 01-02-2009, 00:54
FRC #2526
The propellers are perfectly safe as long as they don't exceed their maximum rpm, the rate at which we are spinning them is no where near their maximum rpm (the maximum is about 13k rpm). Having them spontaneously exploding is not a huge concern to us, having balls getting in the way of the props is a much bigger concern. (oh and its 12.25 in in diameter btw ;D)
Unread 01-02-2009, 00:59
I'm taking Eric's word on this one.
I highly doubt that the inspectors will give a crap ( or too much) about the safety of the precious orbit balls.
I say that if a finger or even a hand can pass through the cage, then it is not safe.
+$0.02
FRC #2526
-Greg
Yeah, that's why we have a 3.5 multiplier on our props. So the 2.5 k rpms you get on a CIM motor at peak power output you don't have nearly enough pushing power. Our props are actually push them at about a walking pace.
See, ideally you reach 88% - 94% the speed of sound on the tips of your props in order to get maximum power.
Unread 01-02-2009, 01:02
FRC #2526
+$0.02
Who is dumb enough to stick their fingers in there?? Plus the props are far enough inside the cage that even if you can get your fingers in, they wouldn't touch the props.
PLUS who's running around the field trying to catch a robot by sticking their fingers into the cage with spinning blades???
Unread 01-02-2009, 01:07
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Pit area? Although safety should always be first, sometimes mistakes are made.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 01-02-2009, 01:09
FLL #2054
Well, our blade/s pull too much power to gear it up any. We start tripping a 40A breaker at a 1:2 ratio. The size of our prop combined with the really high pitch, and the fact that the blade is cut to give a lot of thrust in one direction.. gave us a pretty good acceleration to around the speed you're describing at 3/4 ratio.
Of course we're going for different things. You have them for turning and maneuvering plus a good amount of power. And we're going for sheer power, mainly for getting across in a straight line fast, pinning, and then dumping.
Tell you what, you make it to Atlanta for Championships, we'll have an Overdrive style race.
-Greg
Fans/Propellers - Are you doing them? Greg Peshek General Forum 15 06-02-2009 19:50
To those who are officers/admins here... synth3tk General Forum 3 26-09-2008 07:06
For those who lack dedication... Pi Is Exactly 3 Regional Competitions 19 09-02-2005 21:26
Some good humour for those who are bored. Frank(Aflak) Chit-Chat 0 09-12-2003 19:11
For those who were wondering... Nate Smith Championship Event 2 22-04-2002 17:25
