Go to Post Just the fact we were selected to compete in the eliminations energized the kids more than anything I had seen - Taylor [more]
Unread 01-02-2009, 00:33
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
Team 665 Fan/s and More
We're having fun with fans and conveyor belts, all in the same robot. Right now we've tested a 22", 3DA airplane prop. It puts out about 28 mph windspeed, and when we tried putting it on a rolling chassis alone that weighed about 90 lbs.. it started pushing it at about 3/4 speed and accelerated to a very nice speed at the end of 16ft. Here's a video of our fan testing: http://www.youtube.com/watch?v=Sw7jg...e=channel_page
Picture of our fan casing (also known as the giant cake dish):
Picture of the fan casing being held up to the robot (this picture has all the conveyor stuff off)
We tried the fan at a 1:6 ratio, we tripped the breaker before we could even get to a decent speed. We're looking at 1:1 as a very good ratio right now. We're looking at the possibility of two non-rotating fans for directional control. 2 weeks is plenty of time....
-Greg
Unread 01-02-2009, 00:37
phr34kR's Avatar
phr34kR phr34kR is offline
AKA: electrical/mechanical/Pneumatics
no team (symbiOHSis)
phr34kR is an unknown quantity at this point
Send a message via MSN to phr34kR
Re: Team 665 Fan/s and More
Nice set up i like it, it seems like it has the potential to aid you in acceleration and handling good luck!
YAY won 6 out of 8 New Zealand VEX competitions!(and only killed Three servos in the process)
at least we made the semis
Its not a hole its a controlled leak...
Winners of the New Zealand excellence award (yay going to Dallas)
Unread 01-02-2009, 00:51
Woodworker88 Woodworker88 is offline
Shop Rat
AKA: Michael Fagan
FRC #0190 (Gompei and the H.E.R.D), FRC #0114 (Eagle Strike)
Woodworker88 is a jewel in the roughWoodworker88 is a jewel in the roughWoodworker88 is a jewel in the roughWoodworker88 is a jewel in the rough
Nice work. Out of curiosity, how much does a prop like that cost?
2005-2008 FRC Team 114 (Los Altos, CA) Lead Machinist and Shop Manager
2009-Present FRC Team 190 (Worcester, MA) Lab Manager
Worcester Polytechnic, Mechanical Engineering 2012
2009 Boston Regional
GM Industrial Design, Regional Champs (thanks 61 and 1099)
"Do or do not. There is no try." -Yoda
Unread 01-02-2009, 01:23
If it's an R/C prop, it could be really cheap or really expensive. It depends on the type, whether it comes balanced or not, and where it's made. It varies. For example, my Aero team buys a particular brand of props. They're made in Australia, and shipping is kind of...well...not cheap. Then the props are carbon fiber. More not cheap. We do the balancing, so that saves a little money. But for your plastic, cheap type, it's not going to be nearly as expensive.
Unread 01-02-2009, 01:26
FLL #2054
We're using a XOAR wood laminated prop. Nothing particularly special, somewhere on the order of $30 per prop. While I'm not quite sure if they're balanced or not, it's certainly been quite smooth in all of our test runs.
-Greg
Unread 01-02-2009, 01:32
-Greg
For better performance, try balancing it. If you don't have a prop balancer, all you need to make one is a couple of magnets, a steel rod, and something to stabilize the prop along the rod. Oh, and a freshman with fine sandpaper...
Find a place that is non-drafty. Set up the magnets just over a rod-length apart, and put the prop on the rod. "Hang" rod between the magnets, and give the prop a light flick. If it just turns, turns, turns, stops, it's balanced. If it stops, then reverses, then it probably isn't. lightly--very lightly sand down the heavy side for a few strokes. Repeat until the prop doesn't reverse.
Now, the motor doesn't have to fight against extra weight half the time. Overall faster prop...
Unread 01-02-2009, 01:37
Shop Rat
AKA: Michael Fagan
-Greg
Wow that's significantly cheaper than I would have expected. I can't wait to see how it turns out when it's all done.
Unread 01-02-2009, 03:01
Now that's a propulsion system
Very nice. Good luck and may the propulsive force be with you.
Unread 01-02-2009, 10:15
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Not JUST propulsion but possibly deflecting balls.
Unread 01-02-2009, 10:55
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
I have a suggestion for measuring prop speed. The device you are using in the video looks for changes in light intensity. The room you are in has florescent lights. Florescent lights flicker 120 times per second. This flickering is picked up by the photo-tach and you will not get a good reading, if you get one at all. (try aiming the tach at the overhead lights, you should get a reading of around 3,600 RPM if you are set for a 2-bladed prop). You should make your readings outside, or turn off the overheads and use an incandescent light source like a flashlight, aimed from the far side of the prop (so the beam passes through the prop) at the tach.
On another note, you probably already know this, but static thrust (and the speeds you will be reaching in the game will be so low that static thrust is all you care about) is not affected by prop pitch, but power consumption is. So the trick is to swing the largest diameter, lowest pitch prop you can get. That will maximize the thrust you get.
For quick analysis, google thrusthp. Tis is a free program that will calculate power consumption, thrust and top speed based on prop diameter, pitch, and rotational speed.
Good luck at your regional!
Former Mentor Team 1771
Former mentor Team 4509
Unread 01-02-2009, 11:22
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
idk why, but something about a propeller on a robot scares me =P But I like the idea
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 01-02-2009, 14:46
sportzkrazzy's Avatar
sportzkrazzy sportzkrazzy is offline
AKA: Zac
FRC #1592 (Bionic tigers and 801 Horse power)
sportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant future
Send a message via AIM to sportzkrazzy
One thing comes to mind when i c this. Air boat lol.
Have u guys thought about counter rotating props?
http://www.freepatentsonline.com/6821169-0-large.jpg
Unread 01-02-2009, 14:50
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
wow, i cant wait to see you guys at the regional
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 02-02-2009, 01:37
zrop zrop is offline
FRC #2526
zrop has a spectacular aura aboutzrop has a spectacular aura aboutzrop has a spectacular aura about
-Greg
I'd suggest trying a 1:2 ratio. Because at peak power output you're gonna get about 2.6k rpm out of the CIM, and if you double that, for that kind of prop, you should be at a very good thrust. Also try to minimize your pitch, otherwise you'll be stalling the whole time. XD
Unread 02-02-2009, 09:57
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
At some point you have to start wondering what all the backwash from your props will do to the other robots on the field, including your own partners. We'll find out in Orlando I suppose
GitHub
pic: Team 665 REAL Chassis, Kinda-Teaser Greg Peshek Extra Discussion 13 25-01-2008 08:14
Team 665 TheFuhr Robot Showcase 13 23-01-2008 13:04
pic: Team 66 lifted once, and will lift more JoeXIII'007 Extra Discussion 4 11-03-2007 14:20
Edit- Can we connect more than one speed controller fan per breaker? DemonYawgmoth Rules/Strategy 7 03-02-2006 21:37
Team 713 and more. Madison Thanks and/or Congrats 0 13-04-2003 13:51
