Go to Post I never wanted to be a teacher. This was the year I learned that I am one. It turns out mentors are teachers. Oops. - marshall [more]
Unread 01-27-2009, 02:35 AM
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
setNewDataSem
I assume the function setNewDataSem allows me to pass a handle to a semaphore that will get processed each time a data packet arrives.
I'd like to use this mechanism instead of polling to see if a new message has arrived. Is this semaphore given (semGive) or flushed (semFlush) each time?
It does not seem to work no matter how I use it.
Thanks
Unread 02-01-2009, 03:49 AM
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Re: setNewDataSem
This actually does work. You can block any task on a semapahore you register this way. There is no need to give the semaphore back each time, it seems the semaphore gets flushed, not given, each time a new message comes in. So this is a great way to not have to poll to see if a new message has arrived.
setNewDataSem wireties Programming 0 01-26-2009 03:30 AM
