Go to Post And the rest of the team helped them, encouraged them, and made a big deal about how awesome it was that we were competing for the Chairman's Award. - Carolyn_Grace [more]
Unread 01-02-2009, 10:45
mahmosh's Avatar
mahmosh mahmosh is offline
FRC #1946
mahmosh is an unknown quantity at this point
Question which motor can we use for the shooter?
our team 1946# want to use a motor for the shooter but we can't use CIM becuase we are using for 4 motors
Unread 01-02-2009, 10:51
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: which motor can we use for the shooter?
You could use the Fisher Price motors, but you probably need to make a gearbox to reduce the speed, but not reduce it as much as the black plastic gearbox does.
We made a gearbox for that motor using a gear out of the black plastic gearbox. It has 4.5:1 reduction. The plastic gear has a hex shaped hole in it, so you can use a hex rod to make a shaft to drive the shooter roller. It might be difficult to make the holes in the correct location, but you might want to give it a try and see if you can do it. This gear reduction should work good with a shooter wheel that is about 5 inches diameter.
Unread 01-02-2009, 10:57
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
You might even use two Fisher Price motors. You will have about the same power as one CIM. Copy Squirrel's gearbox, but use two motors to drive the same gear.
Former Mentor Team 1771
Former mentor Team 4509
Unread 01-02-2009, 11:07
MrForbes's Avatar
AKA: Jim
That's a great suggestion.
Unread 01-02-2009, 11:11
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
I would also suggest the Fisher Price (Johnson Electric) motors. They're 1/3 horsepower a piece (2/3 the power of the CIM, which is 1/2 HP) and runs at 15,600 RPM. Shooter wheels at normal diameter seem to work pretty well direct-driven from CIMs (5,000 RPM), so gearing the FP's down by a factor of 4 or 5 should probably be good (because of the less torque of the motor compared to the CIM) for about 3-4 K rpm. If you can't make a gearbox, Banebots makes some good ones that fit well with that kind of reduction range, and there's also the planetary transmission from AndyMark (3.67:1). With whatever gearbox you use, if it's low reduction, make sure you don't stall the motors, because those FP's have a lot of magic smoke in them, and are quick to release it. When you have a third of a horsepower in such a small motors, there's a trade off in the pounding it can take. They can burn up without ever tripping a breaker.
Alternatively, if you're using the FP motors already, you could use the Banebots motors. They're less powerful (about 1/4 HP), but run faster (17,500 RPM) and don't burn up AS EASILY (that's not to say they don't burn up). Banebots sells gearboxes for these with the motors only, because the motors themselves are only about $5.
Unread 01-02-2009, 11:15
MrForbes's Avatar
AKA: Jim
One reason I suggested using the gear from the FP gearbox is that the team who asked, is in Israel, and might not be able to recieve any parts from the US in time to put them on their robot.
which gearboxes can we use for this year? mahmosh Kit & Additional Hardware 2 09-01-2009 19:52
can we use the cloth for bumpers? strawberymochi Technical Discussion 2 01-02-2007 22:19
Which Controller Can we use? THE_SDMC Programming 4 17-01-2007 22:15
How much of our wheel used for the shooter can be exposed? waialua359 Technical Discussion 4 14-02-2006 13:27
Which do you use a spike or a victor on the Bosch motor? Leo 1529 Technical Discussion 2 20-01-2006 20:29
