Go to Post ...Al Skierk, uh, Skierwike, uh, you know who I mean - Gary Dillard [more]
Unread 01-02-2009, 12:44
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
FP pinion 16t, not 19 as per KOP
We noticed the FP gear ratios are completely different from last year (slower) and in-spite of what the KOP says, the motor has a 16 tooth pinion, not 19. The motor part number is 009680-9015 which is the same as last year so at least we know it is a 12v motor (one year they accidently shipped 6v motors!). But it can not be used as a spare as the pinion is 19.
Anyone else confirm they got 16t pinions ?
Unread 01-02-2009, 12:48
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: FP pinion 16t, not 19 as per KOP
It is indeed a 16 tooth pinion.
How many teeth does the plastic gear that the 16 tooth pinion interfaces with have? I know it's been 80 in the past but it may have changed.
thanks, Vivek
"we don't build robots, we build people"
Unread 01-02-2009, 12:53
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
72 tooth
I think
Unread 01-02-2009, 13:58
vivek16's Avatar
AKA: vivek
Darn, I designed a gearbox for 80 teeth. Can someone give me a confirmation that it's 72 teeth? I'd hate to redesign the gearbox twice.
-Vivek
Unread 01-02-2009, 14:03
MrForbes's Avatar
AKA: Jim
you don't have a KOP transmission to take apart?
anyways....start counting....
this is the first gear in the geartrain, isn't it? the second gear is blue, and has larger pitch teeth on it's attached small gear, right?
Unread 01-02-2009, 14:13
vivek16's Avatar
AKA: vivek
I don't have access to our workshop until tomorrow. I started designing said gearbox yesterday after our meeting and figured the gearbox was the same as previous years. Oops.
Thanks for the picture, that is the gear I am talking about.
I counted, it is 72 teeth.
thanks, Vivek
Unread 01-02-2009, 14:17
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
That gear you posted does have 72 teeth - I'm assuming it is from this year's gearbox, which I did not open yet, since they are usually 79 teeth - 0.8 module, 20 degree pressure angle.
Since we're discussing FP motors, has anyone tested its free-load speed? FIRST specs it at 15800 RPM, but our tests showed 19000 RPM, as I already mentioned here. Some confirmation, either way, would be great.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 01-02-2009, 18:26
vivek16's Avatar
AKA: vivek
What's the OD of that white spacer on the FP motor? Does the OD line up with the inside of the vent holes?
thanks, Vivek
Unread 01-02-2009, 22:14
MrForbes's Avatar
AKA: Jim
I think we measured it variously at 0.795" and 20 mm.
Unread 01-02-2009, 23:31
vivek16's Avatar
AKA: vivek
Thanks, so it's made to overlap a bit with the edge of the vent hole...
-Vivek
Pinion not machined correctly Coachmac Kit & Additional Hardware 2 14-01-2005 10:28
Converting the Bosch Metric Pinion into an English- Specification Pinion evolution Motors 3 28-08-2004 16:30
Picture Gallery Rows-per-Page not sticky Greg Ross CD Forum Support 5 22-04-2004 21:13
Bosch Pinion JamesJones Motors 18 23-02-2003 00:20
