Go to Post Ok, so you are going to use a robot to hold all of those rivets together? - gblake [more]
Unread 01-02-2009, 13:18
nofar#1943 nofar#1943 is offline
FRC #1943
nofar#1943 is an unknown quantity at this point
Problems with the connections to the Keyang motor
We are using a Keyang motor(Keyang motor,12-tooth , PN: 16631023 ,Flowers Tote) in this year's robot, and we are having problems connecting it to power.
Last year's connectors to this motor do not seem to fit and we do not have a clue on where can we find this connector...
Did anyone encounter this problem too?
Because we prefer no to weld the cable to the motor.
I would appreciate your quick response,
Nofar Hamrany, NEAT-TEAM #1943, ISRAEL
Unread 01-02-2009, 13:21
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Problems with the connections to the Keyang motor
Here's a thread on that subject.
Soldering directly to the terminals, when done carefully, is considered a reasonable alternative.
Unread 01-02-2009, 19:27
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
We just solder the wires straight to the terminals
Power connections for Keyang motors aeasson Motors 7 16-02-2008 18:35
How to use the keyang motor program1 Motors 1 24-01-2008 22:42
Problems with the manual of the green target (for cmu cam) Kawashima Kit & Additional Hardware 1 28-01-2007 13:31
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
What's with the New Motor Specs for the Atwood Mobile (Chiaphua) Motor. Robb Gerber Motors 2 23-01-2002 08:58
