Go to Post I looked at it and originally thought it was a crazy idea... then I looked at it again and it still sounds like a crazy idea. - Yipyapper [more]
Unread 01-02-2009, 14:23
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pic: Team 617 Robot
It looks like a wide, gravity fed dumper. I hope you've tried dumping balls this way, because they like to hang up on each other. If you don't have a lot of Orbit balls to test with, you won't be able to see the problem.
Unread 08-02-2009, 20:31
Stepol Stepol is offline
FRC #0617 (Enginerds)
Stepol is an unknown quantity at this point
I'm a 617 mom and wanted to comment on the design with some help from my son. The dumper door works like a roller shade using a window motor to lift and lower a bottom weighted tarp. A vibrating system helps to release the balls from the hopper. It's not top heavy because the sides are made from aluminum screen. They are using the side wheel conveyor because it can extend farther inside the hopper. They are going to fix the bumper issue.
pic: 617 Inventor Robot rohit Extra Discussion 4 14-02-2008 16:22
pic: So far.. inventored robot. Team 617 rohit Extra Discussion 9 27-02-2007 21:46
pic: Team 617 Controller rohit Extra Discussion 1 21-02-2007 13:08
pic: Team 617 Robot rohit Robot Showcase 7 21-02-2007 13:04
pic: Team 617 Robot Remp (Inventor) rohit Extra Discussion 18 14-02-2007 10:54
