Go to Post It takes a village to raise a robotics student... - Bob Steele [more]
Unread 01-02-2009, 14:59
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Get Angle Function in Labview
We are having trouble using the Gyro:GetAngle Function in LV (Update #3). When we put the VI into the program it says its missing LVLIB files and won't load due to the missing files?!
Is anyone else having this problem? If so how did you fix it?
Thanks
Unread 01-02-2009, 15:06
markulrich's Avatar
markulrich markulrich is offline
Head Captain and LabVIEW Programmer
FRC #2129 (Ultraviolet)
markulrich has a spectacular aura aboutmarkulrich has a spectacular aura about
Re: Get Angle Function in Labview
Yep, its an update 3 mistake, just navigate to C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\Robotics Library\WPI\Gyro and select the file it wants, it will remember from then on.
Unread 01-02-2009, 15:16
popo308's Avatar
AKA: Brent
found it thanks!
Get Button subVI for LabVIEW ShotgunNinja NI LabVIEW 1 18-01-2009 21:08
Get pixel color (Labview) kamocat NI LabVIEW 4 24-08-2008 02:28
How do you get servo numbers into Angle Degrees Cow Bell Solo Programming 3 18-02-2007 12:16
Where can I get LabVIEW? Hershey LabView and Data Acquisition 1 21-01-2006 14:38
help: cannot get the picture in the labVIEW program .. (was: need help!! quickly!) liad LabView and Data Acquisition 8 18-01-2006 12:20
