Go to Post All the same lessons that can be learned or taught with custom drive trains can also be learned or taught with custom manipulators and scoring mechanisms, and the latter is far more likely to set your team apart in the competition. - Jared Russell [more]
Unread 01-02-2009, 15:47
Chief Pride's Avatar
Chief Pride Chief Pride is offline
<3
AKA: James Kiefer
Chief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond repute
Re: Threading
I'm having difficulty getting the small code sample to compile, Shinigami. Hopefully, you or someone else could lend a hand?
Here is what I currently have:
#include "WPILib.h"
/** TODO: Change this message.
 * This is a demo program showing the use of the RobotBase class.
 * The SimpleRobot class is the base of a robot application that will automatically call your
 * Autonomous and OperatorControl methods at the right time as controlled by the switches on
 * the driver station or the field controls.
class Robot : public SimpleRobot
	RobotDrive myRobot; 	// robot drive system
	Task CameraThread;
public:
	Robot(void):		// these must be initialized in the same order
		myRobot(1, 2),	// as they are declared above.
		CameraThread("camera_thread", imageProcessThread())
		GetWatchdog().SetExpiration(0.1);
	 * Drive left & right motors for 2 seconds then stop
	void Autonomous(void)
		GetWatchdog().SetEnabled(false);
		myRobot.Drive(0.5, 0.0); 	// drive forwards half speed
		Wait(2.0); 					// for 2 seconds
		myRobot.Drive(0.0, 0.0); 	// stop robot
	void OperatorControl(void)
		GetWatchdog().SetEnabled(true);
		while (IsOperatorControl())
			GetWatchdog().Feed();	//woof.
	int imageProcessThread(...)
	   // do stuff...
		return 1;
START_ROBOT_CLASS(SimpleRobot);
Thanks.
Threading on the CRIO dpeterson3 Programming 4 04-01-2009 17:56
Threading tool not working.... strange? q_prof Inventor 3 20-02-2006 00:14
Muti-threading Ryan M. Programming 19 26-04-2004 09:10
