Go to Post Valentine's day, who has time for Valentine's day?????? I have code to write!! - paulcd2000 [more]
Unread 01-02-2009, 15:33
Yuan Xue Lim's Avatar
Yuan Xue Lim Yuan Xue Lim is offline
Electrical Programmer
FRC #3017 (Project Genesis)
Yuan Xue Lim is an unknown quantity at this point
Send a message via AIM to Yuan Xue Lim
Camera problems(c++)
Hi I'm a programmer from team#3017
We had recently set up the camera for autonomous period.
The servos are working fine(although the horizontal servo is sorta lagging)
When it saw the target, it moved vertically up instead of following it and lost the target.
Can I please get a help ASAP because i got a deadline by tomorrow?
Unread 01-02-2009, 15:37
Maxpower57's Avatar
Maxpower57 Maxpower57 is offline
Fabuloso
AKA: Maxwell V.
FRC #2574 (RoboHuskie)
Maxpower57 will become famous soon enoughMaxpower57 will become famous soon enough
Send a message via AIM to Maxpower57
Re: Camera problems(c++)
few questions:
Are you running one of the demo programs?
Have you updated WPILib to version 3? (released on the 27th)
Have You updated the cRIO to version 11? (also on the 27th)
Unread 01-02-2009, 15:46
Yes I did all them.
All i changed is the pwm servos in the program
[font="Fixedsys"][b]We Don't Hope We will.
Unread 01-02-2009, 15:49
Maxpower57's Avatar
Fabuloso
AKA: Maxwell V.
is this the 2 color tracking program or the vision demo?
Unread 01-02-2009, 15:52
I used the example project provided in the windriver.
is call the twocolordemo
Unread 01-02-2009, 16:03
Maxpower57's Avatar
Fabuloso
AKA: Maxwell V.
Im not familiar with that code, sorry.
I'd add some printf's and see if you can find why the servos are moving when they do.
did you transplant this code from the demo into your code? cause if you did, i'd make sure to destroy the environment and make sure nothing else is affecting the servos.
Unread 01-02-2009, 16:06
hmm ok
I'll see what i can do to deal with the problem.
Thanks for helping
Unread 01-02-2009, 17:41
Eric24's Avatar
Eric24 Eric24 is offline
FRC #1138 (Eagle Engineering)
Eric24 is an unknown quantity at this point
Send a message via AIM to Eric24
I had a similar issue with the code myself and I just found a way around it today. The problem lies within the value of verticalPosition. I discovered that it never gets assigned a value so I made my own variable to use in place of it and that seemed to solve my problem. Good luck, and just let me know if you have any other questions.
Unread 01-02-2009, 18:40
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
try this:
change
// you may need to reverse this based on your vertical servo installation
				//incrementV = verticalPosition - verticalDestination;
				incrementV = verticalDestination - verticalPosition;
to
				//incrementV = verticalDestination - verticalPosition;
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 01-02-2009, 19:47
I will add those into my checklist
Also how can i decrease the lagging of horizontal servo during the searching period?
by lowering the framrate or the pixel?
Unread 01-02-2009, 20:12
Eric24's Avatar
Try changing the resolution from 320x240 to 160x120, that seemed to speed things up for us.
Unread 01-02-2009, 21:38
ic
i'll giv the result by tmr
thx for the help
Unread 04-02-2009, 16:56
we didnt really get it working
wat v do is disable the vertical position
Camera Problems!!! spsteam1512 Programming 0 12-02-2007 13:45
Camera Problems CMB Programming 2 02-02-2007 18:24
Camera Problems 804_twidget1 Electrical 4 27-01-2007 11:28
camera scope problems xrabohrok Programming 4 15-01-2007 20:48
Camera Problems pickle Programming 21 20-01-2005 20:43
