Re: Gyro problem
There are two outputs on the gyro, one for temperature. and one for turn rate. if you use the wrong outputs, you will get the behavior you described. Check your wiring.
| Gyro problem..HELP! | zivo123 | Programming | 13 | 14-04-2008 12:06 |
| gyro problem | Guarana | Programming | 9 | 03-03-2008 15:48 |
| Problem with gyro... | capenga | Programming | 21 | 16-02-2006 19:25 |
| Gyro code problem | AMIRAM | Programming | 10 | 23-01-2006 04:26 |
