Go to Post At this point (after shipping the robot), I'm really looking forward to doing laundry, eating a square meal, and getting to bed at a reasonable hour. - Emily Pease [more]
Unread 01-02-2009, 15:56
Ushio Ushio is offline
Programmer/ Rule Czar
FRC #1262 (STAGS)
Ushio is an unknown quantity at this point
Gyro problem
My teammate didn't even spin the gyro all the way around, but the numbers just kept going up, even when she stopped.
help?
Unread 01-02-2009, 15:57
FRC #1262 (STAGS)
Re: Gyro problem
And we made sure the pwm cables were attached correctly.
Unread 01-02-2009, 15:58
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Gyro problem
There are two outputs on the gyro, one for temperature. and one for turn rate. if you use the wrong outputs, you will get the behavior you described. Check your wiring.
Former Mentor Team 1771
Former mentor Team 4509
Unread 01-02-2009, 16:04
FRC #1262 (STAGS)
Re: Gyro problem
the wiring on it is right, though. we've checked it already. Which is why we're at a loss.
Unread 01-02-2009, 16:12
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Re: Gyro problem
The gyro has to be completely still during calibration (done during open I believe) or you will get the kind of response that you are seeing.
Re: Gyro problem
Check it against the manual. A few mislabled ones escaped into the wild. Your result is typical of wiring into the temperature output.
Rate _should_ be on the outside, temp on the inside.
Unread 04-02-2009, 15:28
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Re: Gyro problem
This continuous accumulation also occurred to our gyro, however, mislabeling was not the cause. We desoldered the wires and then resoldered them, and magically the gyro worked. Try that.
Unread 04-02-2009, 15:30
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Gyro problem
Keeping the wires short will also help the drift(lower capacitance).
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 04-02-2009, 15:40
Re: Gyro problem
I do not believe you, yet. Can you please explain your reasoning?
Unread 04-02-2009, 21:11
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Re: Gyro problem
The gyro produces a voltage that will charge the capacitance in the wire. The longer the wire, the larger the capacitance, longer discharge time, longer change in voltage after gyro stops accelerating. It will also catch more noise if the wires are longer.
Kevin Li
596 - Sciclones
Unread 05-02-2009, 09:06
Re: Gyro problem
What you are describing is phase delay. Drift is where the null value (zero turn) drifts away from nominal, which is interpreted as a constant steady spin.
Your comment on phase delay is technically true, but not on a scale that is detectable. A cable that long will contribute a couple dozen picofarads. With a sampling frequency of 62,500Hz and an output impedence of 100 Ohms, you would need to add a couple hundred thousand picofarads to start to change things.
Since the gyro signal is only in the 0-200Hz(ish) range, I'd wager that phase delay will continue to be imperceptible.
However, the noise comment is very valid.
Unread 10-02-2009, 23:29
DtD's Avatar
DtD DtD is offline
I hope the watchdog starves!
AKA: Pathogen David
FRC #2410 (The Metal Mustangs (Merged from 2334, Hazmat Robotics))
DtD will become famous soon enoughDtD will become famous soon enough
Re: Gyro problem
(If you're using C++, not sure about LabView) Are you trying to read the values using printf or cout? If you output too much it all builts up in the cRIO's memory and slowly comes out the console, so you might just be seeing old data in your terminal.
~DtD
Unread 23-03-2009, 13:06
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: Gyro problem
OK, I am trying to implement an ADXRS300 gyro on our 2009 bot using WindRiver.
I'm starting with a known-good unit from 2008. Using our bench setup, upon outputting printf's, with the gyro completely stationary, I'm getting a steady increase in gyro angle values that (from memory) is around a degree every five seconds or so. The gyro was stationary throughout the cRIO power-up process, and it is connected to Analog Input #1 on the first input module.
Last year, I used Kevin Watson's code, with much success. Kevin's code implemented a rejection deadband (ours was set to the default of 8) to help filter out junk and eliminate drift. Other than SetSensitivity (which I currently have set to 0.005 but will adjust to .00393 now that I've found the specific tuning values we used in last year's code), what other gyro setup/tuning adjustments are possible with WPILib's C++ gyro code, and how would we implement this tuning?
Thanks in advance,
Unread 23-03-2009, 14:08
Team 135 Team 135 is offline
FRC #0135 (Penn Robotics)
Team 135 will become famous soon enough
Re: Gyro problem
We had the same problem. We found it to be our code by running the sample gyro code. Also check that the wires are not reversed, I know that this has been said before, but it plagued us early in the 6 weeks.
Unread 23-03-2009, 15:35
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Gyro problem
If the gyro is constantly returning the exact same high angular velocity, then the problem is your wiring. Take a multimeter and check the voltage between one of the red/black wires and the signal wire. It should be about 2.5 volts in correct operation. To confirm if this is the case, set up your gyro class so it uses an incorrect PWM input that nothing is plugged into, and see if the behavior changes.
Also, double check that your using both the correct SLOT and correct channel. If you only specify the channel, it might be attempting to read the gyro off of the incorrect cRio slot.
If the gyro is constantly returning a varying low angular velocity (1 degree every 5 seconds as posted above is about right), then everything is fine and that is expected.
Gyro problem..HELP! zivo123 Programming 13 14-04-2008 12:06
gyro problem Guarana Programming 9 03-03-2008 15:48
Problem with gyro... capenga Programming 21 16-02-2006 19:25
Gyro code problem AMIRAM Programming 10 23-01-2006 04:26
