Go to Post Everyone needs to start working with what they are given, and start appreciating FIRST, not complaining about what they think FIRST is doing wrong. - Marygrace [more]
Unread 31-01-2009, 01:50
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
servos not responding to camera code
Hi, we are attempting to run the demo camera code on the bot. The code deploys fine and appears to be tracking the colors. The program is set to gimbal, the servo ports have the jumpers put on them. The indicators show that the servo should be searching for the colors however they aren't moving. The digital sidecar is connector to the module in port 4.
Any suggestions as to how I could solve this problem?
Thanks!
Unread 31-01-2009, 02:51
FRC #2477
Re: servos not responding to camera code
Another thing to add is that the RSL light is blinking. I'm not sure what that means.
Unread 31-01-2009, 03:00
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
Thanks!
Did you make the FRC Labview update?
Check these thread: http://www.chiefdelphi.com/forums/sh...w+Updat e+2.0
Unread 31-01-2009, 03:47
Blinking means the robot is disabled. No PWM outputs will be present, so the servos will not respond.
What does the Driver Station screen show while this is happening? (The word "Enabled" should appear, along with a reasonable battery voltage.)
Unread 31-01-2009, 04:19
FRC #2477
I'm no longer at the bot now since it is about 11p here, but if I recall I saw a voltage of 0.0v and it was enabled. The RSL still blinks. Thing is when we run our code, the voltage reads a reasonable value so Im not sure what is different here. The labview program has been updated to the most current update.
Unread 31-01-2009, 04:41
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
There are three different blink rates for the RSL LED.
Here is the documentation:
http://decibel.ni.com/content/docs/DOC-3120
Unread 31-01-2009, 08:28
The camera doesn't use the FPGa at all. Meanwhile the servos need PWMs and are produced by the FPGA.
I think that if you run the dashboard or probe for errors, you will see that your FPGA isn't being loaded because it is an incompatible version. If you see this error, update the image on the cRIO to the latest, 11 I think.
Greg McKaskle
Unread 01-02-2009, 15:18
Shira Shira is offline
FRC #1836
Shira is an unknown quantity at this point
We've got the same problem. Labview is updated with the latest update, we reimaged the cRIO properly, everything else in the demo code seems to be working fine (we get live camera feed, the modules in labview show that the servos should be moving, we tried switching out the servos for other ones, and they are plugged in to the right ports....PWM 9 and 10, matching the default).
But the servos refuse to move.
Unread 01-02-2009, 16:13
Probe the error wire on some of the I/O to see if you are getting a version error such that your FPGA isn't version 11, or if you are getting a watchdog error. You can also see errors by running the dashboard.
Greg McKaskle
Unread 01-02-2009, 16:15
a3aperez's Avatar
a3aperez a3aperez is offline
a3aperez is an unknown quantity at this point
Does the two pin connection next to the PWN channel the servo is plugged in have a jumper? That kept one of the teams I work with stuck for a few hours.
Make sure it's set to Gimbal Track.
You can also test the channel by plugging in a Motor and watching if it moves.
Unread 01-02-2009, 16:16
FRC #1836
Yeah, that was it. Thanks! We figured it out just as I posted...I guess what happened was that we lost the jumpers (or never got them) so we forgot about them...We found some off old victors though and now it is working fine.
Axis Camera responding in the Vision Assistant but not in WindRiver DanDon C/C++ 3 11-01-2009 12:50
Camera code not working.... DemonYawgmoth Programming 5 11-02-2006 09:21
Camera Not Responding To Code itzrobz Programming 2 05-02-2006 12:47
CMUcam default code not responding Kyveck Programming 29 26-01-2006 16:25
CMUCam Servos not Responding on Robot krigby Programming 7 20-01-2006 23:19
