Go to Post Elevator speeches too - everyone should have one. - Swan217 [more]
Unread 01-02-2009, 16:15
a3aperez's Avatar
a3aperez a3aperez is offline
a3aperez is an unknown quantity at this point
Re: servos not responding to camera code
Does the two pin connection next to the PWN channel the servo is plugged in have a jumper? That kept one of the teams I work with stuck for a few hours.
Make sure it's set to Gimbal Track.
You can also test the channel by plugging in a Motor and watching if it moves.
Axis Camera responding in the Vision Assistant but not in WindRiver DanDon C/C++ 3 11-01-2009 12:50
Camera code not working.... DemonYawgmoth Programming 5 11-02-2006 09:21
Camera Not Responding To Code itzrobz Programming 2 05-02-2006 12:47
CMUcam default code not responding Kyveck Programming 29 26-01-2006 16:25
CMUCam Servos not Responding on Robot krigby Programming 7 20-01-2006 23:19
