Go to Post Most of the people who fit the profile of long tenured FIRST mentor are either already on a team or locked up in an institution where they belong... - PayneTrain [more]
Unread 01-02-2009, 17:57
abross's Avatar
abross abross is offline
FRC #5113 (Combustible Lemons)
abross is on a distinguished road
Gyro Sensor
Hello. I was wondering if the gyro included in the KOP, when mounted on a turret (unfortunately off-center mounted), can return information relating to how far from dead center it currently is. I wanted to know if we could use it to get a precise measurement as to how far from neutral our turret has turned.
Thank You.
Unread 01-02-2009, 18:52
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Gyro Sensor
That is not a good use for the Gyro (and off-center is a problem). Better off using a potentiometer with a large gear or something, perhaps connected to the motor moving the turret.
Unread 01-02-2009, 19:49
abross's Avatar
Re: Gyro Sensor
OK. Thanks anyway. That's actually what we're using, but I just wanted to know if there was a way to use a gyro. And one quick question. What does the gyro actually tell you? Number-wise. And if you could give a quick situational example, that would be great.
Unread 01-02-2009, 21:04
Re: Gyro Sensor
The "gyro" is actually a yaw rate sensor. Its output is a voltage that tells how rapidly it is being spun, in degrees per second. There is a characteristic voltage that represents zero spin, and a certain number of millivolts above (or below) that voltage for each degree per second it is turning.
Unread 01-02-2009, 21:20
abross's Avatar
Re: Gyro Sensor
Ok. Thank you. I understand it now.
Gyro Sensor Questions pheadxdll Programming 13 09-04-2008 00:52
ADXRS150 Gyro Yaw Sensor sensitivity? hinewwiner Technical Discussion 5 08-02-2008 09:20
Gyro/accelerometer/Gear tooth sensor sparrowkc Technical Discussion 2 11-01-2008 22:47
ADXRS150 gyro yaw rate sensor Brian M. Electrical 13 17-10-2004 02:28
Gyro Sensor Questions sanddrag Electrical 8 27-09-2003 20:58
