Re: Removing Code
well i was just trying to run 1 motor at first. so i deployed it and it worked fine, but i updated the code, and have been trying for 5 days and have not been successful in getting a motor to run again. btw this is only for teleoperated, i uploaded auto code and itll just go in to auto mode, even if i manually switch it to tele from the driver station....whats going on?
i have tried also uploading the whole project, but that doesnt do anything either |
Re: Removing Code
If you have a motor that isn't moving, and it is a SW issue, you are probably getting an error. You should always probe or look at panels or run the dashboard to see what they are and let them help with the debugging.
Greg McKaksle |
| Removing game pieces from Trailers | PhilBot | Rules/Strategy | 51 | 06-01-2009 17:19 |
| removing trackball from overpass | Tyler Grooms | Rules/Strategy | 4 | 15-01-2008 12:39 |
| Removing Bumpers for Ramp | Gabe | Technical Discussion | 8 | 21-02-2007 10:28 |
| RE:Removing Tetras | matt111 | Rules/Strategy | 40 | 12-01-2005 12:48 |
| Removing Drill pinion | Rickertsen2 | Technical Discussion | 14 | 18-02-2004 13:41 |
