Go to Post "my life is incomplete, my nose has lost the imprint of my safety goggles." - Nin_estarSaerah [more]
Unread 01-02-2009, 23:54
Paul11 Paul11 is offline
FRC #1245
Paul11 is an unknown quantity at this point
Ballast Confusion
Our robot weighs only 90 lbs fully loaded any suggestions on how to get it up to 120? http://www.chiefdelphi.com/forums/im...s/confused.gif
Unread 02-02-2009, 00:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Ballast Confusion
If you want it to weigh 30 pounds more, you could add 30 pounds of metal to it. I suggest steel plate, screwed to the bottom of the robot chassis.
Unread 02-02-2009, 00:01
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Yup, first thing you should add any braces you feel that would be useful.
If that's not enough, make a trip to Sports Authority and buy a 25 pound weight and put it on your robot.
Unread 02-02-2009, 00:02
Add another mechanism to improve performance.
Leave it at 90 lbs.
"Forget" to take your bumpers and trailer hitch off for weigh-in.
Find a 25-30 lb chunk of steel and bolt it on.
Add decorations.
Add armor--Lexan works.
Add more wheels (or not).
Experiment with a properly shielded propeller system.
Unread 02-02-2009, 00:13
FRC #1245
We are going to try to get the weight on the two drive wheels in the back. It is a 18"x6" flat surface. Any mounting would happen off of two 18" bars of 80/20.
Unread 02-02-2009, 00:17
MrForbes's Avatar
AKA: Jim
18 x 6 = 108 square inches. Steel weighs .283 lbs per cubic inch. You'd need 106 cubic inches of steel to get 30 lbs. That's about an inch thick, covering that rear area!
Cast iron sports weights are about that thick, if you got three of the 10 lb weights they might fit back there...maybe...
Unread 02-02-2009, 08:27
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
If you used tubular construction, you can drill a hole in a tube and pour in some lead shot. Cheap, effective, and it doesn't change the look of your robot any.
Unread 02-02-2009, 08:51
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
isn't Lead considered poisonous, much like Mercury and Radon, being the reason that FRC teams can't use lead solder at FIRST events?
Is now an engineer thanks to FIRST.
Unread 02-02-2009, 11:11
Tom Line's Avatar
Vaporized lead can be hazardous if you ingest / breathe it, yes. However, I have been unable to find the rule you're talking about regarding not using lead solder at competitions. Can you please cite it?
Also, I would suggest that there are many dangerous chemicals inside both the battery and the control boards (heavy metals, lead, etc). Unless you plan on somehow eating your control components and battery, they are usually benign. Having lead sealed inside your frame would hardly be dangerous - though it might make quite a mess if you managed to fracture your frame
Unread 02-02-2009, 11:20
Doctorwho's Avatar
Doctorwho Doctorwho is offline
FRC #0467
Doctorwho will become famous soon enoughDoctorwho will become famous soon enough
The weight problem hit our previous year's robot, we used a 14 pound steel plate bolted to the chassis to solve the problem.You could go to your local welding shop and see if they have any scrap steel plate that they want to get rid of.
Unread 02-02-2009, 14:43
XXShadowXX's Avatar
They call me Cody.
This is true...
it was in the safety quiz (a question about using lead free solder, and i got it wrong)
also John Antilla mentioned that it after he said we had a electronic heat gun..
but i don't know the rule in question
Unread 02-02-2009, 15:06
Joining the 900 Meme Team
FRC #0079
You are correct, steel shot is also an option.
397 does use lead to weight our robot for testing. We have several large blocks of it (let me tell you, DONT pick up two brick sized chunks of lead) We just make sure we wash our hands after it. One option is to open up one of the Bimba tanks and fill it with the lead shot then mount that. Frankly, if you break one of those you have bigger problems to worry about.
Whatever you do, keep your weight low and centered over your driven wheels.
Unread 02-02-2009, 15:12
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
If you do use lead, please don't machine it while in the pits.
Russ
Unread 02-02-2009, 15:31
M. Gildner's Avatar
M. Gildner M. Gildner is offline
College Mentor
AKA: Matt
FRC #2620 (Servos)
M. Gildner is on a distinguished road
Lightbulb Methods of adding ballast to underweight robots
I have seen numerous threads briefly mentioning ballast or adding weight, buy none really got in depth. So i thought it would be helpful to start a thread completely devoted to adding weight. All ideas are welcome even those of questionable legality.
Servbot?...
SERVBOT!!!
Unread 02-02-2009, 15:32
M. Gildner's Avatar
College Mentor
AKA: Matt
FRC #2620 (Servos)
Re: Serious Ballast discussion
I'll start it off.
Zip tying weights to the frame or adding armor to your bot.
Armor would be sweet.
Servbot?...
SERVBOT!!!
Ballast Confusion Paul11 Technical Discussion 12 02-02-2009 15:12
Ok serious question ringo115 NI LabVIEW 2 24-01-2009 12:58
Ballast considered extra parts? Gabe Rules/Strategy 9 12-02-2007 10:47
Extra Discussion for Picture Discussion Ianworld Robot Showcase 1 31-01-2005 01:28
Serious OI problems Arrowsmith Control System 8 10-03-2004 14:36
