Go to Post And let's face it their junk is our robot! - jrgrim12 [more]
Unread 02-02-2009, 09:56
Re: Removing Code
I've found this not to be true after Update 3.0a.
If I don't remove the default code (added to the cRIO by Imaging with the latest update) then it will be running at the same time as my newly downloaded LabVIEW code.
You can easily test for this by booting the cRIO while the DS is set to autonomous mode. You'll see the chase lights on the solenoid module until the larger LabVIEW program has time to finish loading and take over.
Originally Posted by BLAQmx View Post
You shouldn't need to manually remove code from the cRIO. Whenever you deploy something new to it the old code will automatically be removed and replaced with the new code.
Removing game pieces from Trailers PhilBot Rules/Strategy 51 06-01-2009 17:19
removing trackball from overpass Tyler Grooms Rules/Strategy 4 15-01-2008 12:39
Removing Bumpers for Ramp Gabe Technical Discussion 8 21-02-2007 10:28
RE:Removing Tetras matt111 Rules/Strategy 40 12-01-2005 12:48
Removing Drill pinion Rickertsen2 Technical Discussion 14 18-02-2004 13:41
