Go to Post The best moments of our lives fall in two categories: those that did happen and those that did not. - Jnadke [more]
Unread 02-02-2009, 12:44
oddjob oddjob is offline
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
Accelerometer class - isn't reading zero at rest?
Do we have a bad KoP board or the code is wrong or missing some setup?
// Declare variables for the 3 axis accelerometer (2 channels wired)
Accelerometer *m_accelerometerX;
Accelerometer *m_accelerometerY;
// create accelerometers
m_accelerometerX = new Accelerometer(2);
m_accelerometerY = new Accelerometer(3);
//m_accelerometerX->SetSensitivity(0.0);
//m_accelerometerY->SetSensitivity(0.0);
//m_accelerometerX->SetZero(0.0);
//m_accelerometerY->SetZero(0.0);
accX = m_accelerometerX->GetAcceleration();
accY = m_accelerometerY->GetAcceleration();
The accX and accY values are about 1.5 each when the board is at rest. Do we need to use SetZero? I tried putting in 1.5 for the value and then accX went to an entirely different non zero value, -2.5 or something like that. Can I just use AnalogChannel and do the scaling in the code?
Floating point math zero flippo Programming 3 09-02-2007 09:00
OI and analog: Zero value Astronouth7303 Programming 1 02-02-2004 16:00
Community Zero archiver 2001 1 24-06-2002 04:08
How about zero qualifying points? archiver 2000 0 23-06-2002 22:01
Zero Hour archiver 2000 4 23-06-2002 21:59
