Go to Post Super Regional? I don't know...if you combine NJ and Philly the universe might tear a hole in itself...and we wouldn't want that now would we? Mwahaha. - George A. [more]
Unread 02-02-2009, 12:29
solomason519 solomason519 is offline
FRC #0519
solomason519 is an unknown quantity at this point
limit switch
help. Does anyone know how to program a limit switch in labview. I have the limit switch hooked up to digital io port 2 i want to program it so that i can stop power to a motor. help
Unread 02-02-2009, 12:53
Kruuzr Kruuzr is offline
Mentor - electrical, software
AKA: Steve Cote
FRC #1922 (Ozram)
Kruuzr has a spectacular aura aboutKruuzr has a spectacular aura about
Re: limit switch
I can't help with the labview part, but did you know that you can hook a limit switch directly to a jaguar controller - no programming involved? (Assuming you are using a jaguar, of course)
Steve
Unread 02-02-2009, 12:58
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: limit switch
Steve
That has been ruled illegal for this year's competition based on <R62>.
http://forums.usfirst.org/showthread.php?t=11658
Unread 02-02-2009, 13:02
FRC #0519
Re: limit switch
which port on the jaguar and do i use a regular pwm cable?
Unread 02-02-2009, 13:04
FRC #0519
Re: limit switch
are limit switches illegal?
Unread 02-02-2009, 13:07
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: limit switch
Limit switches are not illegal, but connecting them to the Jaguars limit switch inputs is for this year.
Unread 02-02-2009, 13:10
FRC #0519
Re: limit switch
o ok. so can you help with the programming?????
Unread 02-02-2009, 13:21
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: limit switch
For an example, look at the compressor code. The pressure switch is effectively a limit switch, just operated by air pressure.
Former Mentor Team 1771
Former mentor Team 4509
Unread 02-02-2009, 13:31
DRH2o's Avatar
DRH2o DRH2o is offline
AKA: Dan Waters
FRC #1598 (Team Talon)
DRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of light
Re: limit switch
Try This
Connect the joystick to all three joystick in connectors. Select their DIO port used for the limit switches. Connect speed to set_motor speed
Unread 09-02-2010, 08:50
LavaEagle LavaEagle is offline
FRC #2660
LavaEagle is an unknown quantity at this point
Re: limit switch
http://frcmastery.com/try-me/frc-walkthrough/
Oddly enough I just happend to watch this, how to hook it up in LabVIEW is covered in this video.
Limit Switch Problem Boydean Programming 3 13-02-2008 16:32
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
Using a limit switch thunderbolt Programming 1 02-04-2007 19:36
limit switch wedellm Electrical 4 16-02-2007 13:01
